587,011 active members*
3,875 visitors online*
Page 1 of 2 12
Results 1 to 20 of 40
    Oct 2011
    141
    My X3 Power Draw Bar!
    Another floating power draw bar design for my X3 mill. I only had to machine a base plate and spacer. Everything else was bought from McMaster or Ebay.
    I bought the new draw bar and Bellville washers directly from Tormach. It is the same parts that they sell in their complete kit! Fits nicely on the X3. I am also using their TTS system.
    Foot switch, 5 port valve, and 4" Fabco cylinder bought from Ebay.
    Last picture shows the orginal drawbar from the X3. The cap came off!!! The cap is actually held on with a pin and it sheared off. The Tormach drawbar appears to be one piece so no worries about the head coming off.
    Here's the vid again:
    [ame=http://www.youtube.com/watch?v=tbUNKx5wrmw&list=UUPw_8uMdPFrSkW8e4MuBlZQ& index=1&feature=plcp]Movie_0004.wmv - YouTube[/ame]
    Attached Thumbnails Attached Thumbnails IMG_2193.jpg   IMG_2203.jpg   IMG_2199.jpg   IMG_2207.jpg
    Nov 2009
    724
    Nice! great to have the PDB dont know how I lived without it for so long!!
    One question though, why is the air bypassing on the downstroke?
    You will generate more force and it might actuate a little faster if the air actually goes into and stays IN the air cylinder:stickpoke.
    JTCUSTOMS
    "It is only when they go wrong that machines remind you how powerful they are."
    Clive James
    Oct 2011
    141
    Quote Originally Posted by cornbinder23 View Post
    JTCUSTOMS
    It's not the prettiest thing but it works. Focus was on not having to machine too many custom parts for the drawbar.
    I have a muffler/valve on each exhaust output that I can use to control the speed of the downstroke and upstroke (you can see them attached to the solenoid) The air noise you are hearing on the downstroke is from the exhaust that is set very restricted and the air is still flowing into the cylinder. I was just being extra careful since this was the first run and I didn't want the downstroke crashing down on my drawbar head too quickly. I could definitely tune the exhausts later to speed things up.
    This drawbar is so cool. For some reason I'm mesmerized by this stuff and can keep watching it or cycling it forever on video or real life.
    Next step is to add a counter weight for the Z axis. Then I'll do the pulley swap mod that PriddyShiddy did to speed up the spindle. 2000rpm is way too slow for a bed that can do 100 to 200 IPM. Scared to swap the spindle with higher speed bearings so I'll just see how hot things get. Then I need to get the Fog Buster (which means I need to buy a compressor too) Almost there .....
    Jan 2007
    24
    Nice job.
    How long is the Tormach drawbar? I'm wondering if it will work with my G0704.
    Rob
    FS: CNCFUSION Deluxe x3 kit NEW. -SOLD
    Oct 2011
    141
    Quote Originally Posted by robcap View Post
    Nice job.
    Rob
    Tormach Power Drawbar is 11 7/8" from shoulder to thread end
    Power Drawbar Part# 31320 @ $38.50 ea
    Belleville Washer Part# 31319 @ $2.50 ea
    Dec 2010
    1230
    very nice! what was the total cost? I'm having a hard time convincing myself to make one since it will put my tormach purchase further away.
    on the bearings and heat I generally run the spindle around 3500-4000 rpm and the bearings get pretty hot after an hour or two but not terrible. I think the best thing to do is to buy a new spindle and quill from LMS for around $225 rather than try and fight the old bearings off. I'm ordering a G0602 later this month which is what I've been putting off the bearings for. with a lathe I'll be able to polish the spindle to get a good fit on the bearings.
    I'll try it and if it works out (and you dont have a lathe) you can order the spindle and have it shipped to me to polish and I'll mail it to you, just pay shipping.
    Honestly I've been shocked at the number of hours I have on my x3 with virtually no issues. I'm doing short run manufacturing and job shop, literally hundreds of parts, and not one beak down other than fuses and my quill mount for my light causing spindle to seize.
    on the counterweight if I were to do it again I would go with a flat plate that weights could be added or removed from by installing pegs/dowels/solid bar sticking out of one side. on the other side I would put two very small casters and instal the pulley on the wall so that the weight rides up and down on the wall. my bucket-o-cement gets to swingin when doing lots of caned drilling cycles. so far it hasn't hurt anything, but I don't like seeing it.
    Oct 2011
    141
    Quote Originally Posted by PriddyShiddy View Post
    Thanks. Major costs of power drawbar:
    footpedal $34 ebay
    12V 5 port solenoid $50 ebay
    exhaust mufler x 2, Allied Electronics $10
    Fabco 4" dual stage pneumatic cylinder $45 ebay
    Drawbar $38.50 Tormach
    Bellevilles x 6, $15 Tormach
    Total approx $200. Add another $50 for things liking hoses, hose fittings, shaft collar, spacers, springs, washers, nuts, aluminum base plate, threaded rods, etc.
    For ~$250 you have a system for the X3 mill that you could adapt later for a Tormach since it basically uses the same drawbar and Bellevilles. You'd need to make a new base plate and use longer threaded rod.
    Dec 2010
    1230
    at that price it's damn tempting... just so many things to do.
    Oct 2011
    141
    The key is to get a cheap Fabco (or equiv) multistage pneumatic cylinder from Ebay. Looks like they are harder to get now - probably due to folks on CNCZone building PDBs
    Feb 2012
    17
    Hi!
    Can you, please, specify the air cylinder more exactly.
    I probably have to order it,
    we have here ( Finland ) very difficult to find used air cylinders.
    Sorry for my bad English
    viking45
    Oct 2011
    141
    Quote Originally Posted by viking45 View Post
    Hi!
    viking45
    See attached file.
    I got the Fabco MP4x1-2-1-FF-MR from Ebay for $45 + $30 shipping
    This is the 2 stage extend, 1 stage retract, 4" diameter cylinder with
    1 inch throw
    Ideally, you would want a 3 stage extend, 1 stage retract, 4" diameter,
    1/2" throw
    MP4x1/2-3-1-FF-MR
    Tormach started with a 2 stage 4 incher but switch to 3 stage after
    beta testing because some users compressors with 100 PSI couldn't open
    the draw bar. In actually, using the antiseize compound would have
    helped out a lot so the 2 stage is good enough but not ideal.
    Also, by dropping the throw from 1 inch to 1/2 inch your stack height
    doesn't get too large.
    Attached Files Attached Files
    Feb 2012
    17
    Hi!
    Thank You "ImagineRobots". That was a quick reply !!
    With your specifications I can go through the European
    manufactures or order one from US.
    I'm waiting for a packet from Tormach with Drawbar and Belleville washers.
    We have midnight here
    Regards
    viking45
    Feb 2012
    17
    Hi!
    The Drawbar and Belleville washer are here and were not expensive. But the pneumatic cylinder is. Fabco factory price is $324 + delivery to Finland etc, total costs will be about $500.
    So, do I really want it ??
    viking45
    Dec 2010
    1230
    There are a LOT of cheaper ones with longer throws. 500lb force against a lever with a 4:1 ratio is still 2000lb. not much to fabricate, just a pivot point an inch away from the draw bar, a 5.5" bar with a half inch hole 1.5" from one end, and the cylinder pushing down on the long end.
    measurements are for simplicity as the throw should equal the actual arc travel of the long end of the rod. fulcrums are fun. mechanical lever multiplication is linear and can be easily calculated
    Oct 2011
    141
    Hi!
    viking45
    I guess it isn't cheap shipping to Finland from the US!
    Keep checking Ebay. There is a 5 inch bore, 3 stage listed for $73 (MP5x1x3x1ft-NR). It is a much larger bore than what you need but you can just reduce the PSI to the cylinder. Maybe you can also take it apart and modify it as a 2 stage.
    Feb 2012
    17
    kx3 drawbar
    Hi!
    Thank you for advice's. I'll keep on seeking, in the meantime I'll make dimensioned drawings of the Sieg kx3 cnc Mill Headstock...if anyone has not already done it.
    viking45
    Feb 2012
    17
    Hi! ImagineRobots
    Is this thread still alive? Does your PDB still work well? I have not put the project aside, but slowly continued.
    I believe I have soon something to show, if there is interest anymore.
    Regards
    viking45
    Finland
    Oct 2011
    141
    Hi! ImagineRobots
    Regards
    viking45
    Finland
    She's still working great. My favorite part of the mill is the PDB and Tormach TTS holders. I'm sure folks would like to see your progress.
    Feb 2012
    17
    Sieg KX3 Power Drawbar
    Hi!
    My version is now under testing.
    Here is a video of my Power Drawbar:
    Power drawbar - YouTube
    Also here is a couple photos of my ringlight.
    Regards
    Viking45
    Oct 2011
    141
    Hi!
    Regards
    Viking45
    Viking,
    Nice ring light and welcome to the power drawbar club! It looks like you managed to get a 3 stage, 4" diameter, 1/2" throw Fabco cylinder shipped to Finland. I see you used a nice blue anodized bottom plate that looks like 3/4" thickness. I don't see any plate flexing from your video unlike my 1/2" thick plate.
    Next you'll be getting a collection of TTS holders for all your cutting bits. Tip: lot's of folks have purchased a set of 10 ER20 collet holders for $99 off of Ebay plus shipping. Great price, really high quality and works with the TTS system. Ebay seller is bsello168 and he ships international air. He now has ER25 and ER32 sizes.
    Here's the thread on CNC zone:
    http://www.cnczone.com/forums/tormac...et_chucks.html
Page 1 of 2 12
  1. Power Draw Bar for NM-145
    By cteufert in forum Novakon
    Last Post: 07-17-2014, 08:21 AM
  2. Power Draw Bar
    By nitewatchman in forum Tormach Personal CNC Mill
    Last Post: 11-06-2012, 02:33 PM
  3. Power Draw Bar
    By Blakea1790 in forum Tormach Personal CNC Mill
    Last Post: 11-10-2011, 09:56 PM
  4. Power Draw for 7.5hp VFD
    By Southbend Sam in forum Phase Converters
    Last Post: 04-25-2011, 08:43 PM
  5. Power Draw Bar for 770
    By oknups in forum Tormach Personal CNC Mill
    Last Post: 01-27-2011, 02:05 AM
