Hello everybody,
After 6 months studying, learning, having help from friends and researching I finally successfully converted my Chinese DC-K40 machine to a TB6560 “blue board” to make it cut vectors with mach3.
That Moshi driver/Moshidraw did not work well, and do not cut vector files from ACad CorelDraw.
I first would like to say that I am a non-professional, but I understand a little about electronics, solder wires and mach3 software (this is the most difficult part)
This is a small thread showing all the steps I did to convert my machine. Like I´ve said: I AM NOT A PROFESSIONAL, and I`M NOT EARNING ANY $$$$ FOR THIS.
As a non-professional I´ll use a simple language to explain all the steps.
This is my machine´s conversion, and using a generic TB6560 board that I´ve bought from Ebay. Remember that your machine inner setup and board can be different from mine.
All hints from expert guys to improve other´s conversions would be welcome for this thread.
I´d like to apologize for my poor English, but I´ll do my best to show as much as pictures as necessary from the mach3 software setup and shots from my machine.
Some advises are import since it is a laser machine:
1-Always use laser goggles when the laser is working.
2-Always use laser goggles when the laser is working.
3-Always use laser goggles when the laser is working.
4-Always use laser goggles when the laser is working.
5-….
6-This is not a toy
7-Did you get it?
First of all you have to understand the basic: the TB6560 “blue board” is not a controller, it is a just a driver controlled by mach3 software. Mach3 software is the brain of all. The TB6560 board will be just a driver that will get all the information from mach3 and send to the stepper motors, and will receive information from the machine´s limit/home switches to send to the mach3. Period.
(I´m explaining it because I first thought that the TB6560 board was the controller, and I´m sure that most of the non-professional people thought same way)
I recommend a good read on mach 3´s manual since it will be the machine’s controller. G-Code (the code that mach3 use to do all the work) is not difficult to understand, but you have to spend some time studying like I did.
I will not explain mach3 to anyone. I will just show the setup page pictures.
Just for information; you will not need to change any wire that goes to the front panel; this panel will work as was working before the conversion. There we have a laser on/off pushbutton, a laser fire test button and a potentiometer that increases the laser power to cut a vast array of materials and thickness.
Remember: the TB6560 board will not control the laser fire; MACH3 will do that through the 25 pin serial port. Although the wires to control the laser fire will be soldered in the TB6560 board, it will just be a simple way to get the input from the 25 pin serial port.
You will see that I use the relay to turn on/off the laser (only in the beginning and ending of a work), it is just a safe procedure, and the relay do not control the laser trigger while the work is in progress. In the next lines you´ll see how it works.
