586,068 active members*
4,307 visitors online*
    Nov 2004
    3028
    Fmdc Led Pattern Decode Table
    Attached is a PDF of what the LED pattern means on a FMDC.
    George
    Attached Files Attached Files
    Nov 2005
    72
    Quote Originally Posted by machintek
    George
    I was looking at this the other day (have the same PDF). According to this the error I get is " 9513 counter failure ( S6, IC 32 ) " I had a friend of mine look at this board before but there is so much on it he did not know where to start. Could we assume the problem may lie somewhere related to IC 32 on the board? Appears to be a Z axis chip. I swapped it with the X and made no difference. Also, what is "S6"?
    Nov 2004
    3028
    I would need to find a legible schematic of a FMDC or see a board. Next time at the office, I will see what I can find.
    George
