586,110 active members*
3,171 visitors online*
IndustryArena Forum > CAM Software > SprutCAM > Help with process
    Jan 2011
    Help with process
    I have a 3D design that I did in Alibre. It actually could be machines using 2.5D techniques I believe. It's not very complex, but I seem to fail and trying to use SprutCam to do the work.
    I must be missing something...
    For example. the 2 long edge cuts are 45 degree cuts and could be done with that type of cutter the entire length of the piece (once it was the fundamentally correct width). Once those are complete the top cross notch cuts could be done...
    so, can someone help with we process with Sprut, do you have to use intermediate version of the design to accomplish these goals?
    Here is the IGS file to help with this discussion.
    Oh, and it should be oriented such that the long side is the X axis, the thickness (narrow distance) is the Z axis and the width (side with the cross slots) is the Y axis (or at least I think that is correct.
    Thanks in advance,
    Alan
    Attached Files Attached Files
    Aug 2009
    986
    I was going to type up how I'd machine that. But it actually took me less time to just program it.
    Of course, I haven't calculated feeds, speeds or depth of cut. This is an example only, so don't try to run it on your mill. This is an example of strategy only, and is far from perfect.
    This program assumes that you have a piece of stock that is the exact size you need.
    You can do the first operation in the vise with the part sitting on parallels. For the second operation, you will need to make a fixture that engages the long slot on the rail, and has two tapped holes for mounting screws. It will have a cross section like an upside down T.
    The angled pieces (chamfers) are going to be the hardest part to get right. You will need to choose your chamfer mill, and do some measuring to find out exactly what shape it is. Verify that it's a true 90 degrees, verify the diameter, and find out how large the flat on the tip of the mill is. Sprut needs to know all of that in order to get the chamfer depth right. If you fudge the numbers on the tool definition, you'll wind up scrapping your part.
    Jan 2011
    Quote Originally Posted by TXFred View Post
    Fred, thanks so much.... this I think can help me learn how the heck you did that ...
    Appreciate it up front.
    Aug 2009
    986
    Quote Originally Posted by aadamson View Post
    No problem at all. Play around with that file, and if you have specific questions, reply back to this thread and I'll see if I can answer them.
    Frederic
  1. understanding the process
    By tipaj in forum Uncategorised CAD Discussion
    Last Post: 05-04-2011, 11:47 PM
  2. Finishing process
    By tjskcnc in forum Jewelry Design Software
    Last Post: 06-12-2009, 10:01 PM
  3. Manufacturing Process.
    By axis_control in forum MetalWork Discussion
    Last Post: 06-10-2009, 07:29 PM
  4. In the process
    By Smitty911 in forum Dolphin CAD/CAM
    Last Post: 05-10-2007, 06:34 AM
  5. Tig Process ??
    By millman52 in forum Welding Brazing Soldering Sealing
    Last Post: 04-30-2007, 07:41 PM
