I'm trying to design a 24" by 14" router for plastics, etc. right now. I'm going with a moving gantry and building it mostly out of 20mm 80/20, but I'm stuck between two base designs right now.
The gantry uses skate bearings mounted on angle aluminum, and the whole gantry might weigh ~4 pounds in total.
Two of these squeeze in on each side. Don't worry about the gantry or anything else for now...
The first question: Should I use 20mm T slot with 3/4 angle aluminum bolted to the sides, or should I use a rod based approach (e.g. 5/8 cold rolled steel) on the base? (Look at the CAD model pics below if you have no idea what I'm talking about) The stiffest option is the one I want.
The second question: If I go with the rod approach, should I use:
A: Gas pipe. I've heard
B: Electrical conduit (Medium wall, 1/2 size?)
C: Cold rolled steel rods. Mcmaster sells medium carbon steel rods for a good price, I'm thinking 5/8?
D: W-1 unhardened drill rod. Not sure if it's actually stiffer, but worth a shot!
As you may have been able to guess, I am under a REALLY tight budget. Actual rails are way out of my league...
Any help would be appreciated!
