Does anyone know where to de-select the X0. home move at end of program in the processor. Ive been deleting it every time I post.
Which post processor are you using? Look for the section peof
remove the "X0.",Code:pbld, n$, *sg28, "X0.", "Y0.", protretinc, e$
Edit the post. Be sure to make a back up copy in case you mess up.
I found it psof, but not peof.
Which post are you using? And which version of mastercam?
MPFAN post and MCX4
Do you have allot of time invested in that post? If not I would suggest looking in to mpmaster.
Having said that,
Look for
pretract #End of tool path, toolchange
In that section look for this line.
if nextop$ = 1003 | tlchg_home, pbld, n$, *sg28ref, "X0.", "Y0.", protretinc, e$
Remove the "X0.",
See if that gives you what you want. Back your post up before making changes.
