Hi all. I tried to run before walking, tripped and fell... I have a situation where I need to mill some slots and drill some holes in injection molded ABS parts. I have made some mistakes and am ready to admit them. First I have ordered a Chinese machine (XJ1218) with a 200mm clearance option because the parts that need to be machined are about 6" tall. (I am still waiting for the machine to arrive). I am planning to build a holder and fasten it onto the machines table to make it so that parts can be snapped into place for the repetitious machining. I had the choice of NC Studio or Mach 3 when I ordered the machine and was talked into NC Studio by the sales rep. It seems that this was my first mistake due to the lack of support. However, I am hopeful that it will work okay.
My problem is that I was led to believe that I could use NC Studio to "Drive" the cutter to each location that needs a hole and mark the point in the software. The machine would then know where it would need drill each hole. After that I supposedly could go to each area that needed a slot machined and continue to mark these areas as well. Again supposedly, the machine could then be told to repeat these steps every time a new part was put on it. From what I understand after reading many posts on this forum, this is totally backwards. It appears that what I really need is a CAM program to generate C code to feed into NC Studio.
After reading the reviews I decided to try Sheetcam. It really did seem to fit the bill. However, with no CAD experience my mind got caught in a loop. I won't go into it but I have a learning disability which interferes. However, I make up for it in enthusiasm and can work my way through any problem as long as I know I am doing it with a rainbow and pot of gold at the end. (:
I am looking for suggestions on how to get the machine to perform this task with minimum cash outlay and with minimum headaches. I need a software package that is relatively easy to learn. The accuracy of the holes/cuts only needs to be about +/-.005 but I do need repeatability because each part that I need to machine costs me $300 so scrap can add up fast. :nono:
After this project I am going to want to use the machine for others so a software package that I can progress with would be great.
Any suggestions?
