visual mill 2012 will not produce arc to arc moves in either G02 or G03 on my Heidenhain 151 controller!!! Does anyone know a way around this issue?
still no luck?
I would post this in the official Mecsoft forum. --ch
so far Mecsoft has been very helpful, but it appears to be more of a Heidenhain thing. I'm not sure how to alter our post. Hoping Rick@Heidenhain can be of some help.
The issue I am having is that the transition from an inside arc to an outside arc will not work or vise versa, it will run with a G01 in between the arcs with a straight or angled line but wont if they run consecutive
Maybe another decimal place. The ends of the arcs may not be coincident due to rounding errors you can't see.
