586,108 active members*
3,354 visitors online*
Thread: turning RFQ
Results 1 to 7 of 7
    Feb 2006
    1260
    turning RFQ
    Mild steel,
    Need 1 part
    If it works.....Don't fix it!
    May 2004
    4519
    +/-.0005 on the ID. What are you using this for? -.00/+.005 on a radius for rope? That is crazy. If I were to even attempt such non-sense...nevermind. Just walk away...just walk away...
    Jan 2008
    449
    As the previous poster mentioned, open up the tolerances. I have made quite a few pulleys (none this big), and can honestly tell you V-belts are very forgiving. First the belt should ride nowhere near as low as the bottom of the groove radius if sized properly. I made v-belt pulleys for small block dirt track cars that had engines that spun 8,000 rpms and you would never notice .005 t.i.r. on a pulley. Open up the bore to +/-.0025, and just put a minimum on that radius for strength.
    Feb 2006
    1260
    The ID is for a press fit for a caged needle bearing. & the tolerance can be opened up a bit but not much more in the neighborhood of 3.625 minimum to +.0015 The "V" groove is not for a V belt, but is for 1/2" wire rope. The depth & width of the V is to allow the wire rope to spool across the width of a 36" long cable spool & still self align to the center of the groove.
    The ID size will be finalized once I have the actual bearing in hand (1-2 days) to measure.
    1880
    also where is there a T.I.R. call out? These aren't tough tolerances for a machine shop but the pulley is big.
    but the tolerance for everything but the bearing are a bit overkill regardless of what type of rope it is. lol
    good luck on this for anything reasonable.
    And I would look the bearing spec up its probably more like +000 -.0005
    thanks
    Michael T.
    "If you don't stand for something, chances are, you'll fall for anything!"
    Feb 2006
    1260
    miljnor, I am sure the tolerances & TIR on everything except the bearing bore can pretty much be barnyard tolerances so long as the bearing bore is pretty straight with the rope radius in the bottom of the groove.
    I didn't create the drawing and I haven't seen the old part. I would imagine, but am guessing the entire original part was a forging/casting possibly including the radius of the rope groove. The only real machining being done on the center bore. & width of the center hub.
    Anyone wishing to bid on the part please state the tolerance & TIR you can comfortably hold & I will ask for approval before any actual work is done.
    1880
    T.I.R. Stands for Total indicated run-out. Was actually wondering where that was in the drawing. Maybe my eyes are getting too bad to see it. Usually signified by a cross-hair with a circle around it and an elaborate box with letters in it.
    maybe time for some new glasses.
    thanks
    Michael T.
  1. Turning using a G50 or a G92
    By camtd in forum G-Code Programing
    Last Post: 08-07-2018, 10:10 PM
  2. Turning just does not add up
    By DIFF OVER in forum BobCad-Cam
    Last Post: 02-28-2012, 07:45 AM
  3. Pinch turning or Balanced turning
    By pradeep in forum Mori Seiki lathes
    Last Post: 09-07-2010, 07:55 PM
  4. RFQ turning job
    By fastolds in forum Employment Opportunity
    Last Post: 12-15-2009, 06:28 PM
  5. Turning
    By camtd in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 08-01-2007, 06:40 PM
