586,626 active members*
2,654 visitors online*
IndustryArena Forum > CAM Software > UG NX > moriseiki post for nx
Results 1 to 8 of 8
    Mar 2012
    6
    Red face moriseiki post for nx
    i've just started working with nx8 and i'm trying to build a post for a Moriseiki nmv5000 dcg 5ax BC table table.I'm having trobels with makeing it to put out the right angles for B and C axis in set_csys command.
    Can anybody help me with that ? Maybe somebody has the post allready or just that comand?
    Thank you!
    Sep 2009
    78
    Have you checked the Siemens NX ftp site? If the exact post isn't there perhaps one of them would be a good starting point.
    NX 10.0.3
    Feb 2009
    6028
    If its the fanuc controlled machine, you should have gotten esprit with the machine with the correct post.
    Mar 2012
    6
    Quote Originally Posted by 1 Infinite Loop View Post
    yes i have tried nx site those ones are not finished. those are missing usualy the most important part of a post like mcs rotations .thank you anyway i'll keep reading.
    Mar 2012
    6
    Quote Originally Posted by underthetire View Post
    yes it's fanuc,bad luck for me
    Feb 2009
    6028
    Can you modify the esprit post the machine came with?
    Mar 2012
    6
    the machine didn't came with it.Bad luck again.
    i'm trying now to modifie some how the set_csys command from nx to put out the right angles.no luck until now.
    Dec 2006
    24
    I think you just need VNC ( Virtual NC) definitions. Just use PB to define everything in your post. In my side, I would better using MTD for make sure my post running well.
  1. MoriSeiki SV-503 alarms HELP
    By fiearlacha in forum Mori Seiki Mills
    Last Post: 08-31-2010, 08:08 PM
  2. moriseiki MV40
    By Ghoten in forum Spanish
    Last Post: 11-19-2009, 04:50 PM
  3. moriseiki MV40
    Last Post: 09-23-2009, 12:50 AM
