586,058 active members*
4,694 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > G-REX > Need to add Rotary Axis to Vortech Router
    Apr 2008
    196
    Question Need to add Rotary Axis to Vortech Router
    My router has 4 stepper drivers running from a 3 axis board. My "Y" axis has two steppers, one on each side of the machine. Vortech sells a rotary for this, but they say I have to unplug the "X" axis to use it. My question is If I replaced the existing breakout board & drivers with a G540, can I run another G250 running in parrellel like I have now & still have the 4th axis to have its own port?
    With that said, I do have axis to a G100. Would this be a better option?
    Oct 2008
    Ever figure it out? Don't quote me on this but Im pretty sure should be able to run a 4th axis with a new breakout board. The one that shipped with my vortech had barely enough I/O to connect the minimum stuff. Matter of fact they had the Estop switch connect in series with an axis limit switch so that the machine would only run if the E stop was PRESSED. :-/ If you setup a new break out board you should be able to add a 4th axis without disconnecting anything.
    Apr 2008
    196
    I am not sure I follow youi. Would this be wired in series with or parrell to the factory board?
    Sep 2012
    7
    i change my stepper motor driver CW250 and the y axis still will not work (HELP)
    Also they are wires that goes to that y box that i would love some help with the y wires arrangement where to go from here ?
    the computer thinks the y is working ,but have no movements on the y.
    john barker
  1. Vortech 4x8 cnc router
    By Chris1960 in forum Commercial CNC Wood Routers
    Last Post: 04-29-2015, 06:20 PM
  2. Vortech CNC Router question
    By flooded in forum WoodWorking Topics
    Last Post: 09-04-2012, 06:18 PM
  3. Vortech CNC Router Info
    By SheldonB in forum Commercial CNC Wood Routers
    Last Post: 03-11-2011, 04:18 PM
  4. looking at Vortech router
    By NSIMILLGUY in forum Commercial CNC Wood Routers
    Last Post: 02-13-2011, 10:10 PM
  5. Vortech Router info
    By rcs1010 in forum Commercial CNC Wood Routers
    Last Post: 01-05-2011, 08:49 PM
