586,116 active members*
3,251 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > 3 axis CNC controller kit 3 NEMA17 78 oz-in stepper motor + 3 axis CNC board
    Dec 2011
    12
    Hi
    I have just built mi first cnc milling machine
    Using:
    Wholesale 3 axis CNC controller kit 3 NEMA17 78 oz in stepper motor + 3 axis CNC board
    and Mach3 SW
    It seams that everithing is working fine, but i'm getting the following error:
    When i press the up key the controller turns on the led for the Y and Z motors, bloking the z motor util i press the down key!!!!
    I'm also getting a few (to many) times the following error:
    Driver Watchdog triggered
    What does it mean?
    Dec 2011
    12
    Tested again with Kcam SW
    Same problem
    when i send a signal on the pin 5 (Ydir) the z motor turns on and blocks the z motor. when i cancel the signal on the pin 5, it all returns to normal!!!
    1695
    Check your wiring to make sure they're not shorted together.
    Dec 2011
    12
    Solved
    I have brushed the board and it seams that something tiny was shorting something.
    now it runs ok
    Thanks for your help
  1. 'New' 4 axis TB6560 stepper motor driver CNC controller board
    By Doronby in forum Stepper Motors / Drives
    Last Post: 02-22-2012, 04:29 PM
  2. 4 Axis TB6560 CNC Stepper Motor Driver Board Controller with a GGC usb
    By RCjunkie in forum CNC Wire Foam Cutter Machines
    Last Post: 01-24-2012, 04:45 PM
  3. 3 axis stepper motor controller board - question
    By Yellowbeard in forum Stepper Motors / Drives
    Last Post: 04-07-2005, 04:02 AM
