603,781 active members*
2,488 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > What does it means? The parameters of stepper motor datasheet
    Nov 2011
    21
    Hello. In advance apologize about my English.
    I have stepper motor(SM) data sheet but I can't understand some parameters.
    Googling wasn't helpful, and my dictionaries too.
    What does it means?
    Inductance accuracy 10%
    resistance accuracy 20%
    Thank you in advance.
    Dec 2007
    362
    It means that the actual values for inductance and resistance may vary by 10% and 20% respectively from the quoted values.
    Manufacturing tolerances.
    Regards
    Geoff
    May 2008
    132
    The windings on the stepper motor have both resistance (measured in ohms) and inductance (measured in micor henrys). When the motor is buit they have specific values based on the design of the motor. The accuracy is just that, how close to the design nominal value will a specific motor be.
    If the resistance design value is 10 ohms with a 10% accuracy then any motor with a resistance of 9 ohms to 11 ohms would be within speck.
    Craig
  1. Stepper Motor: 23LM-C005-29V - Can't find the Datasheet
    By lodberg in forum Stepper Motors / Drives
    Last Post: 01-31-2012, 01:49 PM
  2. Datasheet for Stepper Motor needed
    By aticio in forum Stepper Motors / Drives
    Last Post: 12-20-2008, 04:53 PM
  3. Stepper Motor datasheet request!
    By leitox in forum Stepper Motors / Drives
    Last Post: 07-03-2008, 04:51 PM
  4. Stepper motor parameters
    By fabsch in forum CNC Machine Related Electronics
    Last Post: 05-20-2007, 09:47 AM
  5. help with stepper motor datasheet/specifications
    By zoltan in forum Stepper Motors / Drives
    Last Post: 08-11-2005, 09:12 AM
