586,350 active members*
2,933 visitors online*
Results 1 to 3 of 3
    Uk cnc part (router) suppliers?
    Hey all
    I'm in the process of building/ designing my 8x4 router, and am looking for a suppliers of the electronics- There appears to be a fair few around, and for a total cnc novice am a bit lost-!!
    Was thinking of a c&cnc type affair- but uk based... or a recommended supplier to get all the bits from?
    in terms of mechanics, i'm looking at a linear bearing type slider-me-bob, with gear reduction to a rack, to reduce backlash and inprove resolution as i want an accurate machine-! are these type things best for router? ie dust?
    in terms of the gantry- that'll be an ali extrusion of some description, with a bought z axis- any recommendations on where to get a decent one of these-
    then theres the spindle- and ideal a quick tool changer- i did find one for not that much ££ but now cant fing find it-!! so again any recommendation?
    then theres the vac table and extractor head to look for-!!
    would be nice to find a one stop shop for all of it-!!
    hope that all makes sense-!!
    George
    hoping to get all the costs in and order asap-!!
    Feb 2012
    -then theres the spindle- and ideal a quick tool changer- i did find one for not that much ££ but now cant fing find it-!! so again any recommendation?
    How much you want to shell out?
    You'll need a VFD as well.......
    High Speed Spindles, Motors & Inverters - Arc Euro Trade
    If you're just carving wood? then a normal wood router will suffice so long as you buy earmuffs as well
    Thanks- ohh they look nice-!!
    can mach3 set the inverter/ motor speeds?
    also is there a reason they don't do a 1/2" collet?
    looking at this badger for the quick change...
    Sorotec - Werkzeugwechsler für Kress
    time to get me some bits...!!
    G
  1. best cnc router suppliers from USA
    By welly2000 in forum Commercial CNC Wood Routers
    Last Post: 11-25-2010, 02:33 PM
  2. Router Bit recommendations/suppliers
    By zeeway in forum DIY CNC Router Table Machines
    Last Post: 02-17-2010, 12:52 PM
  3. Replies: 3
    Last Post: 01-27-2010, 01:08 PM
  4. Ti suppliers?
    By shawncnelson in forum Want To Buy...Need help!
    Last Post: 12-05-2009, 05:10 PM
  5. Suppliers???
    By appicnc in forum DIY CNC Router Table Machines
    Last Post: 10-18-2007, 06:26 AM
