586,103 active members*
3,277 visitors online*
    Jul 2007
    6
    machining a shim
    I need to make a 36" long shim that is 2 1/2" wide x .197 thick and tapers to .082. I thought ecb magnets would be the easiest but the ad says .4 min thickness.I need to make 48 of these and possibly alot more . Any ideas would be greatly appreciated.
    Dave
    Jul 2005
    12177
    Start with stock material 3" wide and 1/4" thick, hot rolled steel (I am asumimg steel shims not aluminum or stainless).
    Make a long fixture so the stock can be calmped along the edges with strips bolted down every 3" or so. The fixture needs to be about 5" x 1" and the clamping strips about 1" x 1/2". Also the clamping strips need to be relieved on the underside so they have a ridge about 0.05" wide which makes contact with the stock about 0.01" in from the edge.
    Bolt the fixture flat on the machine table and make sure the top surface is true to the table surface.
    Take a facing cut off all your strips down to a thickness of about 0.22" to get a smooth surface.
    EDIT
    The way I phrased it above I am implying that the side clamps are used for this operation. I screwed up here: For this operation it will be necessary to use toe clamps so the full width of the stock can be faced.
    This facing operation is just to remove the mill scale surface off the hot rolled steel. Cold rolled steel could be used making this facing unnecessary but after the taper machining it is likely the cold rolled would curl badly.
    End of EDIT
    Now remount the fixture on a slope to match the taper of the shim.
    Machine all the strips to the final taper.
    Remount the fixture flat on the table.
    Make a wider clamping strip that can 'reach over' the strip and clamp just short of the side the clamping bolts are on.
    Machine the sides off the strips to get your final width.
  1. Shim Stock Machining/Forming Options
    By cmnewcomer in forum MetalWork Discussion
    Last Post: 03-12-2020, 05:24 PM
  2. BF20 Shim Column? (Solved)
    By zerodegreec in forum Benchtop Machines
    Last Post: 09-07-2015, 04:08 AM
  3. Shim the part or the vise
    By Silverbullet555 in forum Benchtop Machines
    Last Post: 02-03-2012, 11:10 PM
  4. custom springy shim washers
    By Zogg in forum MetalWork Discussion
    Last Post: 02-20-2011, 04:13 PM
  5. Proper Method To Shim?(for Tramming)
    By FLUTE HEAD in forum Uncategorised MetalWorking Machines
    Last Post: 05-23-2005, 04:46 PM
