586,108 active members*
2,986 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Tool Definition & Verify
    May 2007
    781
    I have been using MasterCAM for about 4 years now. One question that I never seem to have time to ask is about how the tools work in the verify screen.
    The tool def. is
    Cutting dia.
    Shank dia.
    Flute length
    Length to Shoulder
    and
    Overall stickout from holder
    I have always wondered why they bother with the flute length because in verify the shank cuts just as well as the flutes. There is no visual indication until you get to the holder at which point it turns red.
    I normally leave the holders turned off for speed reasons.
    So for most normal end mills I have been defining the shoulder equal to the flute length and the shank equal to the cutting diameter plus 0.2 so at least I get a rabbit cut on the part in verify.
    Just wondering how others handle this or am I missing somthing?
    May 2004
    4519
    Good question. Seriously, the way I handle it is, I do not make depth cuts more than the flute length of the tool and I do not make total depth more than the tool stick out from the holder. For the set up man, I add appropriate notes to the tool name for when it is posted, like: 0.500 FLAT MILL 3 FLT NECK DOWN 2.200 OUT
    May 2007
    781
    That is generally what I do.
    Just that between the interuptions of doing 4 or 5 things at once and some indexer jobs with multiple work offsets from different angles it can be easy to miss something and rub a shank on the part.
    Thanks.
    May 2004
    4519
    Another good point is if you need a tool sticking out more than the flute length, use reduced shank tools.
  1. Tool Holder Definition Files?
    By dkaustin in forum SprutCAM
    Last Post: 05-16-2010, 03:34 PM
  2. V22 won't verify tool path? WHY? HELP!!
    By cncjunky in forum BobCad-Cam
    Last Post: 07-07-2009, 03:14 AM
  3. Dovetail Tool Definition?
    By rc30fan in forum EdgeCam
    Last Post: 10-05-2006, 07:54 PM
  4. Tool: Ball Nose definition in BobCad
    By rherman in forum BobCad-Cam
    Last Post: 09-20-2006, 09:48 PM
  5. Tool definition
    By David Da Costa in forum Mini Lathe
    Last Post: 07-04-2006, 04:48 PM
