I have a few jobs that require more metal removal and figured a GMT 2.5" FM45 could be my answer. I also noticed right after I order the 2.5", they also make a 3" FM45 that also has the same size 1" bore... This might be next on my list if the 2.5" works out.
I've always wanted to try and TTS this tool and finally have the need for it. A member here has already had success converting this tool, but not much documentation to be found. I'm going to document the process of the TTS conversion for those that might share the same questions.
I picked up a Glacern 2.5" FM45 face mill and a Shars 1" bore 3/4" straight shank last week (recommended from another user here). The Tormach 90° face mill has been great, but 1.5" isn't enough for some of my newer runs. GMT recommends a great starting point of 1500 SFM @ 0.01" per tooth feed rate. However I think this is based on machine with a 10HP or more. I'm also going to post my S&F test results.
So far the shank definitely needs to be shortened. Next I'm going to glue the TTS conversion ring and see how that holds up. My FM45 & inserts should be here some time today.
Here's what I was able to finish yesterday
Note - I removed the holder locking keys before I chucked it.
(not bad, .0003" RO)
