586,347 active members*
3,621 visitors online*
Page 1 of 2 12
Results 1 to 20 of 34
    Oct 2011
    18
    SL-10 - Chucking
    At work my boss has an sl-10 and we were trying to figure out if we can program the chuck to only open to a certain dia so we can use the bar puller without the part falling into the opening. Does anyone have any experience with this or any idea how to attempt doing this or if its even possible???
    James
    Mar 2010
    1852
    Quote Originally Posted by jpthorpe1041 View Post
    James
    Not possible I think. So, use soft jaws and machine with jaws open or only slightly closed, (on smaller bar maybe). May be tricky but you can do it.
    Mike
    May 2004
    4519
    Give some more details, such as actual part diameter and length.
    Oct 2009
    19
    Hass
    machine a metal ring to diameter that suits then slip it over the jaws and this will stop them opening to far.
    Philip
    what machine do you have
    Mar 2010
    1852
    Quote Originally Posted by philippritchard View Post
    Philip
    So, what happens to this ring while the jaws are closed and turning at say 3000 RPM?
    May 2004
    4519
    Quote Originally Posted by Machineit View Post
    Do you remember that window removal we were discussing on another thread?
    Feb 2007
    381
    Why not use Spindle Orientation? Just orient the spindle so that one of the 3 jaws is on the bottom? Then the bar cannot fall in between them. It is sitting on one. Assuming you are using jaws that were machined round for the bar and not using hard jaws. Even if you don't have the Spindle Orientation option turned on, you can still use it...sort of. The option allows you to orient to specific angles. Without it, you cannot choose the angle. It just goes to "0". Of course, this will only work if the chuck is bolted on in the right place for one of the jaws to be down at "0".
    Good luck...
    Mike :cheers:
    Jul 2005
    12177
    Just position the jaws so that with the chuck fully open there is just enough clearance for the bar to slide. The jaw adjustment is about 1/16" so the maximum clearance you can around the bar is 1/16" or less, and this should be small enough that the bar cannot fall down between two jaws.
    Jan 2008
    575
    Quote Originally Posted by txcncman View Post
    This is the most amazing information I have ever seen.
    You can't even post a link to the thread?? (chair) I get irritated by posts that have no actual information in them. Why even post?
    Geof's knowledge/advice is exactly what I would use/do.
    Robert
    The beaten path, is exclusively for beaten men.
    Jan 2008
    575
    But for your information the jaw serrations are 1.5 mm apart(.059") basically the same dimensions that are the jaw stroke, so pretty easy to figure out.
    Robert
    May 2004
    4519
    Quote Originally Posted by littlerob View Post
    Robert
    Does this help?
    http://www.cnczone.com/forums/haas_l...ty_window.html
    Mar 2010
    1852
    Quote Originally Posted by Geof View Post
    In other words, but that is what I said.
    Feb 2007
    381
    I guess I am lost on this one. Yes, the serrations are about 1/16". But that means roughly 1/8" on the diameter. I know, I know... 1/16" clearance. Where I run into issues is with my soft jaws...
    If I bore them to size, and them set them so that they clamp the bar, I end up with one extreme, or the other. Meaning, either they are too close together to hold the part, they are just right to hold the part, or too far apart to hold the part. I am self taught in this, (most CNC), aspect so please forgive my ignorance in this matter. I have tried to bore the jaws with the chuck clamped all the way open in ID mode and then move them out one notch. And I tried to bore them with the chuck clamped all the way closed in OD mode and then move them in one notch. Both have worked great for what I am needing to do. But in either case, I have the same issue. In moving them over the one notch, I get the correct clamping, right in the middle of the travel for the chuck.
    That leads me back to the top. Where I bored them, the part is slip fit in the jaws. Meaning the chuck won't hold it there. If I move them over one notch, it's in the middle of the travel and works great. If I move them one step farther, now they are not open enough when the chuck is open for me to get the part in.
    Maybe some of you 3-jaw chuck gurus can school me on this a little. We normally use collets. We only break out the chuck when it is absolutely necessary. And even then, I have a set of jaws I made up to take Warner&Swasey collet pads, so I am not experienced with this whole "chuck jaws" dilemma.
    Mike:drowning:
    Oct 2011
    18
    sounds like an easy solution I will def do that, also does it always take a while to switch out the collet holder for the chuck on these or is there a special trick to it????
    2932
    James
    You could always use a spindle liner.
    Oct 2011
    18
    whats a spindle liner??
    2932
    This is one style. Some folks make them in house.
    CNC Lathe Accessories Spindle Liners
    2932
    Here's another source.
    Spindle Liners, reduction tubes - Machine tool lathe accessories
    An added advantage is reduced vibration at higher RPM's.
    Mar 2010
    1852
    Quote Originally Posted by gizmo_454 View Post
    Mike:drowning:
    While the same issue, it's a different question. Why don't we start with the machine ID and the part size.
    Either way, I would caution against machining with the jaws open, as it does not mean they will be concentric on the part when closed.
    Mike
    2932
    James
    Yet another option would be a jaw boring fixture.
    http://www.usshoptools.com/current_y...pdf/PGS_10.pdf
Page 1 of 2 12
  1. Nexus 250 Chucking direction
    By 250my in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-22-2017, 06:57 AM
  2. ID Chucking Brass with No Marks
    By jheal4 in forum Uncategorised MetalWorking Machines
    Last Post: 02-16-2011, 10:23 AM
  3. Takisawa EX-110 Internal Chucking ??
    By Smyers75 in forum MetalWork Discussion
    Last Post: 10-30-2010, 04:30 PM
  4. Chucking on Tapered Hex
    By Tazzer in forum MetalWork Discussion
    Last Post: 01-18-2009, 02:18 AM
  5. spline chucking
    By reachraghu in forum Work Fixtures / Hold-Down Solutions
    Last Post: 04-09-2007, 09:14 PM
