I have a small CNC mill—Roland MDX-540. According to the specs, the spindle is 400W and operates on 120V. The spindle speed can go up to 12,000 RPM. When doing my rough cutting on 6061, does anyone have any recommendations on speeds? I usually rough cut with a 1/4" flat end mill. I am get inconsistent results so I am trying to figure out if it's my settings or something mechanical. I already have a new belt that goes from the spindle to the motor on its way as the one I have looks really worn and may be slipping. The problem that I am having is that once in a while the spindle will get stuck in the block I'm cutting. Yesterday I had no problems and it ran like a champ at 10,000 RPM cutting about 35 inches/minute. Today to help with the problems I am cutting at 8,000RPM and 9 inches/minute but it still gets stuck sometimes. Sometimes it will just be cutting a straight path and the bit will slow down and sometimes speed back up and sometimes get stuck. My software has a meter that shows load on the spindle motor and it never really goes above 30% today—yesterday I was running it just under 50%. Does it mean my end mill is worn out? Any insight would be great!
