586,072 active members*
4,602 visitors online*
    Jan 2007
    29
    FANUC 6T PARAMETER
    Hi I have a Ikegai with a Fanuc 6T control and when I add my offset values my CRT adds them to the screen value so if my program was written to say GO X1.0 Z-2.0 and I add say X-.800 and Z-.500 in the offset page
    CRT screen will now read the difference as
    X .200
    Z 1.500
    NO0222 N0222
    I would prefer
    X 1.0
    Z -2.0
    NO0222 N0222
    Is there a way to change a parameter so the offset value is not shown???
    2932
    Not sure if this is the one you need or not, but it's the only one I found.
    0010 bit 2
    1: The position programmed is displayed in the present value display
    0: The actual tool poosition with tool offset and tool nose radius comp is displayed
    Aug 2011
    2517
    that's the one. it needs to be set to 1 so it shows the programmed position
    Jan 2013
    34
    need 6t manual
    hi i have ikagai 6t fanuc control machine the machine spindle dont start manual&mdi mode.i check spindle drive alarm led all led light blink checked the pcb board m,p,p1,n pin power supply,24,15,-15 volt down any help me thank you.this is imported machine i need 6t manual.
  1. Parameter for using G68 on Fanuc 11M
    By 4thaxismachine in forum Fanuc
    Last Post: 01-02-2024, 03:47 PM
  2. Fanuc OM Parameter 907
    By techscan in forum Fanuc
    Last Post: 11-29-2011, 02:13 AM
  3. Fanuc OM DNC Parameter
    By amurphysmu in forum Fanuc
    Last Post: 11-20-2009, 12:16 AM
  4. Fanuc OT parameter(s)
    By erwin1958 in forum Daewoo/Doosan
    Last Post: 03-27-2009, 04:36 AM
  5. parameter fanuc 18t
    By rmosier1 in forum Fanuc
    Last Post: 06-17-2008, 06:47 PM
