586,366 active members*
3,266 visitors online*
    Jan 2012
    16
    HEIDENHAIN iTNC530
    Dear every one
    I have machining center with HEIDENHAIN iTNC530 control ,when i turn on machine ,i have {exchange buffer battery} .
    I want to know if i exchange it ,parameters and program of machine will be clear ? or no ?
    best regard
    ali
    Jan 2011
    31
    you need to exchange it as soon as possible as this is back up power for memory when machine is powered off
    mick
    Nov 2008
    69
    Well, all the information except the date and the clock is on the harddisk.
    So you won't loose parameters nor programs.
    Anyway, I too advice you to change the battery. It is Renata CR2450N.
    Make sure you will get the right battery. (not just normal 2450)
    Jukka
    Apr 2012
    Make sure you have the machine powered up when you change the batteries. I bought a used machine and by the time I got a big enough phase converter(5-6 mos) it lost all machine parameters and programs and previous owner didn't make a back up copy of parameters. Someone should make battery tender like for motorcycles to keep plugged into 110 to keep batterys charged. Mine with heidenhain uses 3 AA batteries.
    Good luck, JD
    Oct 2013
    8
    Re: HEIDENHAIN iTNC530
    I am on a Hermle 800u with a Heidenhain iTNC530 controller....it had a fat fingered tool calibration program that someone deleted. Is there anyone that can give me some help with a program that calls up tools 6" from the trunion? We are using a vacuum plate and a 3" gage block for setting tool length offsets.
    Thanks in advance
  1. Heidenhain iTNC530 on GROB 550
    By r_searay in forum Post Processors for MC
    Last Post: 05-22-2020, 01:43 PM
  2. Heidenhain iTNC530 cycle
    By YWKim in forum Uncategorised MetalWorking Machines
    Last Post: 08-09-2013, 05:19 AM
  3. Heidenhain iTNC530
    By Jay Roy in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-07-2011, 06:31 PM
  4. Heidenhain iTNC530 First StartUp
    By Leha_Blin in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-29-2008, 06:30 PM
  5. Heidenhain iTNC530, how to change plane?
    By Martynas2 in forum G-Code Programing
    Last Post: 11-23-2008, 04:58 PM
