586,913 active members*
2,875 visitors online*
IndustryArena Forum > CAM Software > Vectric > Vectric Aspire Export
    Oct 2006
    16
    Question Vectric Aspire Export
    Can Aspire export the 3d models you create to be able to open them in MeshCAM or CamBam?
    I read through their site, but can't tell if their export comments refer to 2d files or 3d.
    Matt
    Yes, you can export them as .stl files. Not sure what advantage you'd have using MeshCAM, as Aspire probably gives you a little more control over the toolpaths. (I do have both, btw.)
  1. Aspire V2 y Cut 3D
    By bigsergio04mex in forum Spanish
    Last Post: 03-17-2012, 07:23 AM
  2. Any info on the Vectric Aspire compatibilty?
    By Syngyn in forum Torchmate
    Last Post: 06-18-2009, 08:36 PM
  3. aspire, vcarve pro
    By cabnet636 in forum Commercial CNC Wood Routers
    Last Post: 03-16-2009, 10:56 PM
  4. Aspire!!!
    By cabnet636 in forum Vectric
    Last Post: 02-23-2009, 06:15 PM
