586,032 active members*
2,762 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > I need help with Arduino and a ULN2003 driver board
    Dec 2010
    313
    Hi everyone,
    I am trying to connect a driver board I have to an Adruino.
    In a nutshell, I need to know what pin "step, dir, min, max" are on the driver board. The driver is labeled "in1, in2, in3, in4" for the I/O's on the controller, and labled "A, B, C, D" for the motor connection.
    Below is the I/O configuration to connect the stepper drivers to the Arduino, it is for a 3D printer project.
    Digital I/O #0 = RX
    Digital I/O #1 TX
    Digital I/O #2 X step (Is this in1 on the driver?)
    Digital I/O #3 X dir (Is this in2 on the driver?)
    Digital I/O #4 X min (Is this in3 on the driver?)
    Digital I/O #5 fan
    Digital I/O #6 heater
    Digital I/O #7 Y dir (Is this in2 on your product?)
    Digital I/O #8 Y min (Is this in3 on your product?)
    Digital I/O #9 X max (Is this in4 on your product?)
    Digital I/O #10 Y step (Is this in1 on your product?)
    Digital I/O #11 extruder motor pwm
    Digital I/O #12 extruder motor dir
    Digital I/O #13 Y max (Is this in3 on your product?)
    Analogue I/O #0 (D14) thermistor
    Analogue I/O #1 (D15) valve pwm
    Analogue I/O #2 (D16) valve dir/Z max
    Analogue I/O #3 (D17) Z min (Is this in3 on your product?)
    Analogue I/O #4 (D18) Z dir (Is this in2 on your product?)
    Analogue I/O #5 (D19) Z step (Is this in1 on your product?)
    I hope someone can lend me a hand, and thanks for your time.
    Rob C
    what is a cnc, prototyping, cnc prototyping, interactive article what is a cnc, build your own CNC, build a 3D printer
    Dec 2010
    313
    The picture of the Driver Board
    I forgot to add a picture of the Driver board, sorry....
    Hi everyone,
    Digital I/O #0 = RX
    Digital I/O #1 TX
    Digital I/O #5 fan
    Rob C
  1. Arduino Mega/Big Easy driver 4 axis foam cutter
    By sschering in forum CNC Wire Foam Cutter Machines
    Last Post: 04-03-2015, 02:40 PM
  2. NEED HELP with uln2003 stepper controller
    By Dude22 in forum Open Source Controller Boards
    Last Post: 03-21-2012, 05:19 PM
  3. Arduino and commercial Breakout Board
    By Kvirre in forum Controller & Computer Solutions
    Last Post: 05-10-2011, 07:08 AM
  4. ULN2003 to run at bigger amp
    By same79 in forum CNC Machine Related Electronics
    Last Post: 01-13-2011, 12:29 AM
  5. Uln2003
    By ipodman1991 in forum CNC Machine Related Electronics
    Last Post: 12-03-2006, 06:54 PM
