With any luck my IH geared head will be history in the very near future. It's been problematic since day 1. Apparently the Chinese guy who ran the press which installed bearings on the gear shafts didn't notice when one shaft diameter was WAY out of tolerance and just crammed the bearing on anyway. The inner race was likely split from the day is first arrived at my shop. The bearing blew up and spun in the head for who knows how long. With all the comments about noise, I just assumed this was normal. So the first head rebuild came with a new, oversized bearing pocket in the head as well as the normal clean out.
I also took that opportunity to replace the spindle bearings at which point I found an enormous amount of metal crud inside the quill, waiting to fall into the lower bearing. Removing it required a long shaft grander and more than a little time as no amount of brushing in the parts washer was getting it all. At the time, I picked up a grease seal and bored out the threads at the bottom of the quill too. Installing the seal without turning the spindle nose down didn't seem to cause much trouble, but then again, I don't use this machine much.
It's been about a year of very infrequent usage and a constant oil leak which I finally decided was intolerable. During a small part project, it was like the machine was bleeding all over it during machining. Gear ol from the head and also some kind of thick black greasy stuff from around the spindle nose. The Kluber spindle grease is white so I assumed it must be burning up in there or something. It turns out that the oil from the head had washed all my expensive grease right out of the bearings.
The oil seal at the top of the spindle was easy enough to find and replace, but sweeping the head with a magnet brought out a bunch of metal... again.... All gears come back out, I clean it all up again, reassemble and within a few seconds, I'm already seeing metal bits floating past the site glass. Putting a magnet over it grabs them pretty good even through the plastic. So I add a few more magnets and start looking at a belt drive conversion. That's another story.
While it's apart I took the opportunity to grind down the spindle nose to the spec 2.0625" for the oil seal and replace the seal itself. I also ground the outer surface of the quill as I'm planning a clamp-on aux spindle and wanted a good perpendicular surface to mount to.
Reassembling the whole thing goes like normal, but running it up, it's getting much hotter than usual. After less than one minute at 3400 rpm, coolant splashed onto the spindle nose boils instantly. Like an overheated skillet.
I spent the day jacking with preload settings, running in at lower rpms. Nothing works. Finally, out of desperation, I pulled the oil seal to be sure it wasn't the cause of the heat. Lo and behold, the spindle nose is still uncomfortable, but no where near the "boiling" temperature as before.
The next step will be AG bearings and belt drive, but I'm not sure what do do about the seal. I know Cruiser has been down this road and seems happy, perhaps someone can chime in and tell me what I'm doing wrong (plus any advice on the AG swap) as the new drive will top out around 9K if I can make the spindle take it.
It's been a frustrating weekend and I just had to vent.
Ken
