586,655 active members*
3,446 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Lathes > adding a stepper to a TL-1 lathe
    Mar 2012
    I want to use a stepper motor on a TL-1 lathe to turn an indexer for a tool post i'm making.
    I'm having alot of difficulty finding info on how to send output to it.
    I don't know what parameters to use to auxiliary output when a toolchange is called. (Instead of opstop and alarm when calling a T, I want to go to a subroutine that outputs pulses to my motor.) Any help would be appreciated.
    I keep coming back to M121 codes and M51-58 codes.
    Is there a comprehensive work on auxiliary add-ons to HAAS equipment?
    Aug 2010
    190
    You will need an external BRAIN, something like simple logic from an output of your haas controller. IF you want to do it cheaply, PM me and ill show ya how
  1. Adding a coolant pump to my new lathe
    By widgitmaster in forum Mini Lathe
    Last Post: 09-06-2011, 03:43 PM
  2. Stepper seems to be missing and adding steps
    By mrlttlman in forum DIY CNC Router Table Machines
    Last Post: 07-03-2011, 04:29 AM
  3. Adding terminal boxes to stepper motors
    By jphinney in forum Stepper Motors / Drives
    Last Post: 01-17-2009, 03:44 AM
  4. re adding dros to stepper sys
    By woffler in forum CNC Machine Related Electronics
    Last Post: 03-06-2008, 05:11 AM
  5. adding cnc to lathe (which one)
    By mark c in forum Mini Lathe
    Last Post: 03-04-2005, 02:39 AM
