586,116 active members*
3,460 visitors online*
    Aug 2003
    327
    Thermal Expansion
    Hey,
    Is anyone building their machines with thermal or any expansion in mind.
    If so, what precaustions/systems have you employed to cater for this.
    Andy - you do not need to respond.
    /Michael
    Jun 2004
    463
    I am building mine all from steel, so differential expansion won't be a problem. If you are building an alumuinum frame with steel rails and screws, you might see some problems on a larger machine in an unheated shop. The thermal expansion rate for aluminum is 24 parts per million for each degree C, and for steel it is 13 ppm. For a 48" long axis, aluminum would expand about .0012 inches per degree C, and steel would be about .0006 inches per degree C. With a 48" axis, in an unheated shop over a 20 deg C temperature range that would be an expansion difference between aluminum and steel of .012 inches, which sounds significant to me.
    May 2005
    1810
    The best bet is to keep the equipment in a climate controlled environment if this is a concern. Most high precision or larger machines that I am familiar with are in controlled environments for this reason.
    More importantly - where are your measuring tools and standards kept? These grow and shrink, too! If your hot part was cut on a warm machine and measured with cold tools - there's no telling where your dimensions really are!
    Scott
    Consistency is a good thing....unless you're consistently an idiot.
