586,123 active members*
3,231 visitors online*
Results 1 to 7 of 7
    Jul 2005
    66
    Scored some steppers!
    At work they were tossing out a bunch of old electronic equipment. I scored quite a few steppers, including a few which are 1A 3.2 volt, and the online spec says they are 1.30 lbs/in torque! (wow) and 1.8 deg per step..these things should have some nuts. Now I probably could build that cloth cutter or a very large plotter...
    -nt20
    35538
    1.3 lbs-in = 20.8 oz-in.
    1695
    If that's the stall torque, then the motor is surprisingly weak for something that draws 1 amp.
    Apr 2004
    678
    1.3lbs-in = 0,15Nm !!
    If there are any nuts involved, they must be wedged inside!
    My guess is they are 1,3Nm. That seems about right for 1A 3,2V if it's a fairly modern design. (1,3Nm = 184 ozf-in).
    Einar
    Nov 2005
    105
    what about printer stepping motor ? Mitsumi M42SP-5
    Jul 2005
    66
    Aw crap you guys are right - I looked at the datasheet and it is only .7125N-m so yes 1.3lb/in is correct. Guess it's not so hot then. Should still be plenty powerful enough for a large belt driven plotter though.
    I couldn't find any printer steppers around here lately.
    -nt
    Apr 2004
    678
    Quote Originally Posted by nikolatesla20
    Uhh!?!?! Is it?
    Go get this, and try again:
    http://www.joshmadison.com/software/convert/
    Einar
