Which commonly used controllers (Fanuc, etc.) are most similar in processing (G-code library, etc) to the DSP controllers that come on the Chinese machines?
Ok, I'll try to rephrase...
Who is using a DSP controller with their machine and what CAM software are you using?
Vectric Aspire or any of the Vecrtic software is well suited and outputs .tap format.
I you f enable f code on Dsp which gives feed rate control to suit your applied tooling
