I need to put a slight 10deg bend into Alu plates that are roughly 100mm X 50mm X 6mm thick without damaging the plates too much.
Will this sort of Heath Robinson device using a bottle jack be OK or will I need an hydraulic bench press?
The material is 6082 T6.
Thanks in advance.
