586,103 active members*
3,474 visitors online*
IndustryArena Forum > Other Machines > Engraving Machines > Engraving, what tool on 3 axis mill
Results 1 to 7 of 7
    Jun 2011
    Hello,
    I'm looking to add my company logo to parts I make on my 3 axis CNC mill. What is the best tool to use?
    Something like this?
    4mm SOLID CARBIDE 70 DEGREE ENGRAVING / CHAMFERING TOOL GBR NEW AND BOXED | eBay
    If the above is correct, what speed/feed should I be running in aluminium and steel?
    Regards
    Ricky
    Oct 2010
    103
    I use ball endmills. Although you have a limited range of usable width, I like the finish better. The one I use most is a 1/16" ball endmill. You can cut small enough width for characters as small as about 1/4" and larger, depending on "weight" of character (line width). Not to mention you can run 2 or 4 flute so you can feed it harder than a single flute engraving tool. Spin it as fast as you want in aluminum and feed accordingly
    As for small chamfering, I use 90 degree point drill mills.
    Jun 2011
    I've tried that, but i'm struggling to spin it fast enough I think. I cannot get a good finish in aluminium. My max spindle speed is 3000rpm's. I've been feeding at approx 50mm per min with a 2 flute 3mm end mill.
    Jun 2007
    78
    For line engraving I use a Taegutec 1mm carbide ball end running at 3500rpm, F30 plunge & F60 run in ally. 2x passes to engrave 1mm deep then fill with paint.
    V bits aren't much use to you, they need 1000's of rpm.
    Jun 2011
    Quote Originally Posted by Babba View Post
    I'm using a 3mm at the same feed and speed doing a 1mm cut deep cut. Using flood coolant. But get a terrible finish. I thought I needed a fast speed. Maybe not.
    Oct 2010
    103
    Quote Originally Posted by Rickylee53 View Post
    If it can work for you, larger ball endmill and less depth for the same line width may make it cleaner. I run a 1/16" (approx. 1.5mm) mostly at .006" deep (.15mm).
    If you don't need the depth, try a 6mm ball at .4mm deep.
    And make it a 4 flute
    Jun 2011
    Had much better results today using a 2mm ball nose cutter at 0.2mm depth, running 3500 rpm's and F30 plunge and F100 feed.
  1. Engraving Tool Advise
    By MFchief in forum Tormach Personal CNC Mill
    Last Post: 03-29-2022, 12:56 AM
  2. Drag engraving tool in UK
    By stk2008 in forum DIY CNC Router Table Machines
    Last Post: 08-16-2014, 10:26 AM
  3. Engraving tool sources
    By esquire in forum Engraving Machines
    Last Post: 12-14-2010, 11:54 PM
  4. Right tool for engraving at aluminium - CNC
    By KIBLA`s in forum Engraving Machines
    Last Post: 12-11-2010, 04:38 AM
  5. Laser Engraving Retro - on a 3-axis Mill?
    By joecomunale in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-26-2006, 05:52 AM
