586,069 active members*
3,588 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Okuma LB15 OSP 5000L
Results 1 to 13 of 13
    Mar 2012
    I am looking for a post processor for my Okuma LB-15 lathe with the OSP5000L control for MCX.
    Yes is it a legal copy. Please don't tell me I should ask my re-seller. I did, and they want thousands of dollars.
    I would thank for any help.
    [email protected]
    May 2004
    4519
    How many thousands?
    Mar 2012
    Your answer did not help me.
    May 2004
    4519
    It was not an answer. It was a response in the form of a question.
    Attached Files Attached Files
    Dec 2008
    3109
    Tx .. you could of held back.... at least for a couple of "buy me a beer"
    Apr 2003
    3578
    TX you did not ask what version before giving so how do you know what you gave will work? I am figuring the 2X is x2 by chance?
    Cadcam
    Dec 2008
    3109
    Quote Originally Posted by cadcam View Post
    Nah, 2X is 2 AXIS, not McamX2
    the post Tx supplied is for McamX, it will need to have the post updated to the correct Mcam version that is running
    The first line
    Code:
     [POST_VERSION] #DO NOT MOVE OR ALTER THIS LINE# V10.00 E1 P2 T1124227469 M10.00 I0
    the #V10 = McamX
    X2 should be V11
    X3 = V12
    X5 = V14... and so on
    May 2004
    4519
    He stated "MCX". I assume "MCX" means MasterCam X. Not MasterCam X2(12). Not MasterCam 9. If he misstated his needs, that is not necessarily a mistake by me, except trying to be a little helpful. I still would not know if what I supplied would work because I did not post any G-code with it and then test that code on his machine. Maybe we can just place the responsibility where it actually belongs, on the end user, and then leave it at that.
    Apr 2015
    45
    Re: Okuma LB15 OSP 5000L
    Quote Originally Posted by txcncman View Post
    Hello i have a question how to instal that post procesor to mastercam x6? i think i need more files to copy to mastercamx6 directory? i think i need to put to cnc_machines somthig to see in mastercam
    Apr 2003
    3578
    Well this file will not work as there are 3 files and he gave one file. the Machine Def and the Control def are missing that go with the post. then we need to see what version it is for to see were it will work.
    Cadcam
    Apr 2015
    45
    You are right i was thinking the same way , but maybe it is posible to take this pots file and use definition of similar 2 axes machine just replace post file ?
    soooo 4 years later. im about to try that idea. has anyone else?
    Apr 2019
    58
    Quote Originally Posted by RapidButtonPush View Post
    i think i will try it
    and main file is pst other you can make from similar
  1. Okuma LB15 with 5000L error message
    By stude8 in forum Okuma
    Last Post: 07-25-2019, 02:48 PM
  2. Replies: 3
    Last Post: 09-25-2015, 01:52 AM
  3. Okuma Osp 5000L
    By donbe in forum Okuma
    Last Post: 12-20-2013, 05:32 PM
  4. Okuma OSP 5000L M19 Code
    By devangrathod in forum G-Code Programing
    Last Post: 05-12-2012, 07:53 AM
  5. Replies: 2
    Last Post: 06-09-2011, 04:01 PM
