586,115 active members*
3,391 visitors online*
Page 1 of 2 12
Results 1 to 20 of 24
    Jan 2012
    Euro-Hybrid plasma/router
    Hi all,
    I am 29 years old and live in the Netherlands. If my English is bad now you know why.
    I studied Electro-mechanics in Belgium and work in a paper mill as engeneer E&I (electronics & instumentation), in my daily work I have to do with PLCs, VFDs, and (power) electronics.
    After a test build, I am now building a real machine.
    I would like to make a hybrid machine. so I can do some plasma cutting but can also do milling.
    Because I like to weld I make my machine Completely out of steel.
    My machine is 1m x 1.5m by bringing up the gantry I can cut pieces that are bigger then my milling area.
    (Because I live in Europe, I work with the metric system)
    I've been a busy few weeks now and am now waiting for parts.
    Maybe someone can give me some advise or perhaps someone else gets inspiered.
    Thanks so far
    Dr. Arc
    I put some pictures to make it more clearer
    [IMG][/IMG]
    Jan 2012
    Sep 2010
    hi i woul like to share my work...
    here is the picture of my gantry....
    Sep 2010
    here also the video hope you like it....
    [ame=http://www.youtube.com/watch?v=M5zNxsqYViE]CNC Plasma 10ft. x 6ft. controlled by USBCNC Edingcnc Cutting parts 1 - YouTube[/ame]
    [ame=http://www.youtube.com/watch?v=2EqUb6uJGDo]CNC Plasma 10ft. x 6ft. controlled by USBCNC Edingcnc Cutting Part 2 - YouTube[/ame]
    Jan 2012
    [ame=http://www.youtube.com/watch?v=-m_aoWduEXI&feature=plcp]DIY CNC Quick Release Rack and Pinion system - YouTube[/ame]
    [ame=http://www.youtube.com/watch?v=E_FlDinltTs&feature=context-chv] DIY CNC Plasma Rack and Pinion system - YouTube[/ame]
    Hi rexcobey
    I also use Usbcnc from eding, how did you itegrated the thc into the software?
    The software disigner told me there is not yet an torch up, torch down and arc ok feature like mach3.
    For milling, USBCNC from edding is the best!!!
    Sep 2010
    Quote Originally Posted by Dr. Arc View Post
    Hi rexcobey
    for THC i am using the one made by Agelkom from Turkey, this is stand alone THC
    Sep 2010
    Hi rexcobey
    Also do you know Kevin Damen of Damencnc.com, he is developing THC for this USBCNC of eding, i just waiting for this...
    Jan 2012
    Quote Originally Posted by rexcobey View Post
    I know Kevin, I bought most of the parts there. In januari he told me he was thinking of making a complete system together with Bert Edding.
    because it will be a Hybrid i'll make the milling parts first then i'll ad an plasma function on it.
    On your pictures i see both (router / cutter) on the same Z axle, does it work well?
    I'm thinking of making two Z's. one for cutting and one for milling.
    Sep 2010
    yes i have teknomotor in my z axis i put because i need to make a hole on the plate before execute the plasma or oxygen fuel cutting to bypass the piercing
    procedure.
    on my z axis you can see there is two motor, one on z axis and the one on the torch lifter.
    on my z axis the stepper motor are hookup on my usbcnc CPU5 B while the motor on my torch lifter are hookup on stand alone THC
    Sep 2010
    here is some of the picture
    Attached Thumbnails Attached Thumbnails 20120330_145524.jpg   20120330_145533.jpg
    Jan 2012
    Nice pics,
    I use CPU5A4 Economy 4 axes
    but mayby in the future I'll get an upgrade.
    your machine looks very professional, is it just hobby or do you use it commercially?
    Sep 2010
    Nice pics,
    i will use this on my fabrication shop in Philippines, when i'm back there...
    Sep 2010
    Dr. Arc what you plan to cut in your machine?
    Jan 2012
    MDF with the router and sheetmetal max 5mm with the plasma, I build my first MDF cnc last winter just from scrap pieces i had laying around.
    I'll plan on building a new one with the machine I'm building now.
    But it's all hobby and fun.
    [ame=http://www.youtube.com/watch?v=piWEYOGqN44&feature=plcp]Padawan CNC [/ame]
    Sep 2010
    Padawan CNC
    That's nice little cnc machine of yours..... by the way i also plan to retrofit one of my conventional milling machine in Philippines i just saving a little money from my salary here to buy another controller from kevin,
    here is the picture of my milling machine..
    Sep 2010
    i plan to put 4.5NM stepper motor on X and Y axis and 12NM on Z axis
    Jan 2012
    going slow but still working on it
    [ame=http://www.youtube.com/watch?v=E0im2t72uUU&feature=player_detailpage]Zaxis.wmv - YouTube[/ame]
    Jan 2012
    [ame=http://www.youtube.com/watch?v=46B1E9N03eg&feature=plcp]CNC Zaxis buildoff - YouTube[/ame]
    Jan 2012
    Jan 2012
Page 1 of 2 12
  1. Adding Plasma to a CNC Router - Hybrid?
    By Ed3XP in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 12-20-2011, 07:56 AM
  2. CNC Router Hybrid Wood/Steel
    By Grandad in forum CNC Wood Router Project Log
    Last Post: 03-26-2009, 01:24 AM
  3. Plans for Joe's Hybrid CNC router?
    By jeffmorris in forum Joes CNC Model 2006
    Last Post: 08-13-2008, 12:05 AM
  4. Is this worth 100 euro?
    By Frost in forum Stepper Motors / Drives
    Last Post: 06-27-2006, 07:53 PM
  5. Euro fitting Machine torch for plasma?
    By hotponyshoes in forum Waterjet General Topics
    Last Post: 03-16-2006, 05:00 PM
