586,100 active members*
2,615 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Machining a charging handle
Results 1 to 7 of 7
    Nov 2011
    What CNC machine would be the best to machine these AR 15 charging handles? Hopefully you wouldnt need a real expensive milling machine.
    Charging Handle Machined from 7075 T6 Billet Aluminum
    May 2003
    162
    What kind of tolerance do you require?
    Nov 2011
    Quote Originally Posted by foam27 View Post
    It's got to be pretty tight on tolerance because it is one the main component's of a Rifle.
    May 2004
    4519
    What do you consider "real expensive milling machine"?
    Nov 2011
    Quote Originally Posted by txcncman View Post
    The Haas I looked up was $ 65,000. At a gross profit of maybe $ 30 I would have to make a pot load .
    May 2003
    162
    Just get a chinese mill and convert it with ball screws.
    Or, skip it and buy my freshly converted one. G704.
    Oct 2005
    672
    "Best" depends on about a zillion factors.
    - How many do you have to make?
    - What is your budget?
    - How capable are you at doing the service and maintenance on the machine?
    - What are the tolerances on the part?
    - How much room do you have for a machine?
    The charging handles I've seen are all cast (cheap). From memory, the piece would need to start with a chunk about 3/4" x 3" x 8". In 7075, that will be about ~$20 each in material cost. Assuming a dialed in process, well designed fixturing, and no scrap, you might get 3 complete parts per hour on 3 axis vertical. At a shop rate of $50/hr, you'll have about ~$35 into each one. Still have to make the little release/catch doohickey, get everything anodized, assemble with pins and spring, and package.
    With the above numbers, you can pay yourself about $15/hour gross. The rest of the shop rate goes to machine payment, coolant, $ervice/maintenance/repair calls, electric bills, measuring tools, repairing your air compressor, taxes, tool bits, tool holders, fixtures, in$urance, etc.
  1. Can large 4x4 machines handle small machining?
    By ezcnc in forum Open Source CNC Machine Designs
    Last Post: 01-02-2012, 03:09 AM
  2. Battery charging??
    By Nastyzen in forum Colchester Tornado lathes
    Last Post: 02-22-2011, 02:17 AM
  3. Super charging.
    By MrWild in forum Stepper Motors / Drives
    Last Post: 10-25-2005, 12:29 AM
