Hi all,
I am milling using 4th axis with the rotary head in the X direction. Is there a way to set up cut part render to show as a cylinder rather than square.
Hi all,
Make a solid and define it as stock. Can be any shape. CPR will then use that as sock instead of a square.
-Jacob
Thanks for your reply.
It worked !!!
