What was the finish depth of the slot you were cutting? I have found that if your slot is too deep, then your spray coolant doesn't reach the bottom of the cutter and the chips will weld themselves to the flutes clogging them and breaking the end mill. I have learned that for the most part, spray coolant works really well on the outside of the part, but if you're pocketing or cutting deep slots, flood works best. For me anyway.
It could also be that you were a little too agressive on your depth of cut.
You can buy GOOD PARTS or you can buy CHEAP PARTS, but you can't buy GOOD CHEAP PARTS.
