Well, you would still need motors, and a power supply... and wires... but again, you really need to figure out the mechanical parts first, THEN figure out what size motors you need to drive the machine THEN figure out what driver will support those motors, THEN figure out what power supply you need to support that driver. The G540 is probably good for most hobby sized CNC mills, and has a good resale value if you find you need more (or can do with less). But as multiple people have said, sort out the physical machine FIRST.
James hosts the single best wiki page about steppers for CNC hobbyists on the net:
http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
