586,121 active members*
3,575 visitors online*
IndustryArena Forum > CAM Software > PowerMILL > POWERMILL AND ROLAND JWX-10
Results 1 to 7 of 7
    Feb 2008
    6
    Any one has a post for this please?
    I´m triying to do a double side machining ..there is a roland post in the ducpost and it works when I move in 3 axis...but I dont know exactly how to make the 4 axis rotate 180 and mill again.
    any help would be good $%& thankxxx friends
    Dec 2010
    11
    I too looking for the same kind post processor for Mach3.
    Oct 2012
    25
    Post Processor for Mach3
    Hi.
    For 3 axis machining you can use fanuc6m. But you should edit the begin of G-code. but for 4 axis or 5 axis you should have the Multi Axis Post-processor.
    Also you could have a 3 axis post-processor so that the output G-code doesn't need to be edited.
    I can write both of them ( 3axis & multiaxis ) for your machine.
    For more detail contact:
    [email protected]
    subject: Multiaxis
    Oct 2012
    25
    Quote Originally Posted by totxa View Post
    Hi
    in fact you need a 4 axis post processor for your machine.
    Which type of Roland do you have?
    I can write for any 4 axis or 5 axis machine its own post processor.
    for more detail contact : [email protected] subject: multi axis
    Oct 2012
    25
    Quote Originally Posted by ajaydevb View Post
    Do you need a 4 axis or 5 axis post-processor?
    Oct 2012
    25
    Hi.
    you could create a new work plane and rotate it around your machine rotary axis. and do your 3axis machining in new direction. you should rotate the rotary axis manually. It called 3-2 machining. if you have a for axis post processor rotary axis codes will be appear in G-code and will not need too rotate manually.
    Also it will be need for simultaneously 4 axis machining.
    for more detail send your exact request to [email protected].
    Oct 2012
    25
    Do you need a 3 axis post-processor or 4 axis or 5 axis?
  1. powermill 10 and roland mdx 40a
    By cozy in forum CNC Machining Centers
    Last Post: 05-14-2010, 03:28 AM
  2. POWERMILL IN VIRTUALPC
    By IVANDRAGO in forum PowerMILL
    Last Post: 11-11-2009, 11:32 AM
  3. powermill help
    By FandZ in forum PowerMILL
    Last Post: 05-24-2009, 04:25 AM
  4. PowerMill and 2D
    By georgebarr in forum Uncategorised CAM Discussion
    Last Post: 03-31-2004, 05:56 PM
  5. PowerMill from Delcam
    By Dan B in forum Uncategorised CAM Discussion
    Last Post: 12-23-2003, 03:42 PM
