This is some good stuff. thanks guys! should be stickied for sure so i dont have to search the forums again =P
Wow thats the best info I've seen for us newbies, thank you for taking the time to post all this info and pictures. I too think it definately should be a "sticky".
Thanks again
Terry
Regards, Terry Howson
Are you sure that's a Vortex bit? I've been using them for 15 years, and have never seen one like that. Also, there numbering system hasn't changed in that time.
The first looks to be a straight O-flute, used mainly for plastics. The two spiral-Os could be used for either plastics or wood. Don't know much about the last but looks like a downcut spiral. My best guess, if you got them from the same place, they were used for plastics machining.
The Tubelite PDF document at http://www.tubelite.com/docs/electric/TubeltCat_Equipment_pages414-480.pdf
Page 446 shows the 220000 series made by LMT-Belin as "Belin 22000 series - downcut Single Flute Spiral ‘O’" and it's for Aluminum, Brass, Copper, Non-Ferrous Metal.
This is the only related Google reference I found. It's a 3mm shank, 1.5mm cutting diameter, 4mm cutting length, 30mm overall length carbide cutter.
LMT-Belin, LMT-Onsrud appears to be divisions of the same parent corporation.
CarveOne
http://www.carveonecncwoodcraft.com
It appears they were both acquired or merged with LMT (Leitz) between 1999-2001. Prior to that they were not affiliated at all.LMT-Belin, LMT-Onsrud appears to be divisions of the same parent corporation.
Belin is a French company. I've heard they make excellent tooling, but have never seen any.
I purchased #3 Craftsman Professional Carbide tipped 3/4in. X 90° 1/2 in. shank V Grooving Router bits for $18 and change shipped that is less than $6.00 each. They sell for $27.99 each at Sears I don't know how good they are but I will soon find out and yes there are more at that price E Bay..
Lou
http://www.cnczone.com/forums/diy-cnc-router-table-machines/140832-cnc-software.html
Just got a pack of 1/8" Kyocera Tycom endmills from Drillman1 on Ebay, they look and feel much sharper than any of the chinese endmills I have. I have a lot of faith on these for aluminum work, which is what I got them for.
http://www.build.cl
I have a piece of aluminum 17"X 28"X 1/2" I want to start on that next year lets see what I order from Drillman ..
Lou
Very good information,just what i needed:: winery
Thank you for this thread. I'm waiting my CNC to be delivered and I'm finding out the more I learn the less I know.
I have a kind of related question as a get ready to buy bits: my machine has an er 20 spindle and I' m waiting to hear back from the salesman what size collets it has but should I buy full sets of metric and English collets for it or are there really just a few sizes I would need?
Welcome! As to collet sizes, it's probably best to buy collets as you need them. For wood (and probably most metal work you may do) you could get 1/8", 1/4", and 1/2" to start; they're probably the most commom standard sizes. Many performance router bits come in 3/8" so that may be a size worth getting, especially if you will cut a lot of sheet goods.
Similarly, it's probably best to buy tooling as you need them as well. It may be tempting to buy a "mega set" at a discount, but you may find you don't use about 2/3 of the bits in the set. Once you establish what bits you use the most, you can keep multiples of each to minimize downtime in the event of breakage or wear.
As Louie said, 1/8. 1/4, 3/8, and 1/2" should be all you need if you're buying standard fractional size (not metric) bits.
An ER20 spindle should use ER20 collets.
Thanks louieatienza, that's kid of what I was thinking on the collets so glad to hear that recommendation.
As for the bits I learned that one a long time ago unless there is a specific set for something like the Leah jigs etc.
