586,072 active members*
4,546 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 11M spindle rotation is backwards
    Oct 2009
    My spindle rotates backwards. I tried to switch the leads to the motor but this did not help. Is there a parameter that needs to be changed or should I look elsewhere?
    Thanks, Dustin
    Feb 2006
    1792
    Till the problem gets solved, you may interchange M03/M04 in programs.
    I am not sure, but it may have something to do with the ladder.
    Aug 2010
    156
    what did you do? new install? move it across shop?
    does this machine have hydraulics? if it does is the pressure off zero?
    put the motor wires back where they were and swap the incomming legs right at the breaker of the machine.
  1. CCW spindle rotation
    By dougtyler in forum Mastercam
    Last Post: 12-17-2010, 06:27 PM
  2. Tech installed spindle motor fan backwards (now #9)
    By carbidecraters in forum Fadal
    Last Post: 07-10-2008, 03:09 AM
  3. FANUC Ladder Logic Backwards?
    By obieron in forum Fanuc
    Last Post: 12-18-2007, 09:17 PM
  4. Mitsubishi Sinker Spindle Rotation
    By squarewave in forum Waterjet General Topics
    Last Post: 06-02-2006, 12:33 AM
