586,713 active members*
2,950 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc MF-M4 wont Helical interpolate!!!
Results 1 to 6 of 6
    Nov 2011
    14
    Hello,
    We have an older MV-40 Mori Seiki with Fanuc MF-M4. I have a job coming up that needs some thread milling done, but I cant get the machine to Helical Interpolate. I know on most Fanucs it's an option with the machine. I also do know it's just a parameter that needs to be turned on! So my question(s) are: Is there somebody out there that knows the Parameter to turn this on? Can this machine and/or controller even do a 3 axis cut!!
    Thanks in advance!!!
    Sep 2008
    138
    Check your PM
    Quote Originally Posted by bbarber80 View Post
    Hello,
    Feb 2009
    6028
    MFM4=Fanuc 0M
    I've never seen one sold without helical, but i guess it was possible. It is an option parameter.
    May 2004
    4519
    What code are you using to determine helical interpolation? Simultaneous 3 axis interpolation?
    Mar 2008
    16
    Re: Fanuc MF-M4 wont Helical interpolate!!!
    Hi everyone, I just picked up a Mori MV40b with the Fanuc MFM4 controller and I was told that it didn't have the rigid tapping option. Is there a way I can check if it has it and if it doesn't can I turn that feature on?
    Thanks.
    Aug 2011
    2517
    check your PMs
  1. Helical interpolate vs. drill then open with mill
    By Brian FRF in forum Uncategorised MetalWorking Machines
    Last Post: 08-07-2009, 08:27 PM
  2. Fanuc Oi MC Helical interpolation
    By chrisryn in forum Fanuc
    Last Post: 04-17-2008, 08:22 PM
  3. Fanuc 11m won't helical interpolate
    By hoidahl in forum Fanuc
    Last Post: 04-10-2008, 11:53 AM
  4. Trying to interpolate X and A axis.
    By Konstantin in forum G-Code Programing
    Last Post: 11-08-2006, 06:09 PM
  5. Replies: 3
    Last Post: 10-19-2006, 04:25 AM
