I'll post more details here in a bit... our 3 axis CNC has a servo motor that drives the spindle (roughly 5 rpm to 5,000 rpm). It is controlled by a simple potentiometer to set the speed. The potentiometer goes to a control box (literally a black box LOL) that then goes to the servo motor. It looks like it has an encoder on it, but not sure whether that is even being used.
Sometimes when the potentiometer is rotated from 0 to any speed, nothing happens. Sometimes after a couple of seconds it will lurch into action. Other times, everything is fine and works as expected. Still other times, if the potentiometer is moved to some speed, if the motor doesn't begin turning, if the spindle is rotated slightly it will lurch into action.
I suppose that it could be the potentiometer, but I wonder if it could be something with the motor. Maybe a capacitor that helps it start to turn when it is first signalled to turn?
I'll post the motor type and model a little later, but anyone have any ideas of where I should begin trouble shooting?
To be clear, the motor is controlled directly / manually with a potentiometer, it is not controlled by the CNC software (Mach3, FYI).
