Originally Posted by
oilyamerican
Thanks for the reply.
I sent the motor out to a local shop that works on such things and they ran it with various DC voltages, checked the draw, etc. etc.
They said it checked OK.
So, I will be switching the Z and A leads on the control boards and see what transpires.
Hopefully, outside of some adjustments, my problems will be solved.
Then I will send the Z board out to be gone over.
Anyone know if the HAAS will operate with an unused control board removed ????
It will operate with the "A" axis board removed, as long as the axis is disabled, which it should already be.
