586,060 active members*
3,888 visitors online*
    Apr 2005
    76
    Does K-Cam read "D"?
    "D" as "tool radius compensation number".
    If so, I would need to use G41 or G42 ?
    What would a lind of code look like profiling with a Ø.25 Endmill?
    Thank you for any direction or help.
    Charlie
    Apr 2005
    76
    Thank you Gerry.
    According to that Kellyware example you posted, someoneone loaded a DXF into Kcam and got a G-Code complete with Cutter Compensation!
    I have never been able to use what K-Cam gives me because the "Z" axis is called for after every few lines, and the G-Code is jumping up and down, running all over the place!
    When I load a tool from the tool box, it will compensate to the left, then to the right, and often goes in little circles from one line to another, so I have not been able to use K-Cam in this manner at all.
    I can load a part profile (G-Code) written by another program and K-Cam will run the Stepper Motors from it, but when I try to use Cutter Compensation, It goes crazy, So what I load is what I get, any changes I make, I need to do it before giving it to K-Cam.
    I love the big display and the CNC Controlls, but use it to run the stepper Motors only.
    Surely, I just don't know how to use it, as I said, I love the display.
  1. Replies: 21
    Last Post: 01-23-2015, 11:17 PM
  2. Control will "punch" but not "read"
    By dansteinmetz in forum Fanuc
    Last Post: 04-06-2010, 10:10 PM
  3. Macro to read machine "power on"
    By jakk100 in forum G-Code Programing
    Last Post: 04-12-2007, 03:15 PM
