I have the Kflop/Kanalog combo I and I have a few questions.
1 - I see that the kflop has a "generic" list of what some I/O would be used for on the kflop, like encoder and home/limits on JP1. I see where the encoder connects on the kanalog but not seeing where the home/limit I/O on the kanalog is mapped to from the kflop.
2 - JP2 says that if only JP1 is needed for encoders that JP2 inputs are general I/O and can be used for other things. To use those inputs do you need to use JP9 for connection are can you use JP2 as the connection point?
3 - What kanalog outputs are normally used for step/direction? I will be connecting to DG2S-16035 servo drives.
4 - If using the Opto inputs for home/limit switches (the are 5V inductive) I'm guessing that I would need another 5V supply, and should not use the same supply that is powering the kanalog.
5 - Can some of the outputs on the kanalog be used to turn LEDs on/off? was planning on using a 5V supply with the appropriate series resistor.
6 - I see that I would need a breakout board of some kind to access the GPIO on JP12. Any one know a good source for one of these. Not sure what it would even be called.
Getting closer to having my KMB1 retrofit done. I have 95% of the hardware mounted, and about 30% of the wiring done.
-Wes
