586,390 active members*
3,087 visitors online*
IndustryArena Forum > MetalWorking Machines > Hardinge Lathes > Anyone using a MANUAL chuck on their CHNC lathe?
    Sep 2010
    196
    I just bought a CHNC-1 that is being shipped in the next few days and I'm looking for a manual chuck to fit the A2-5 spindle, or an adapter plate to mount a manual chuck on an A2-5 spindle. If you are using a MANUAL chuck on your CHNC-I, II, III or Quest lathes, could you kindly post the brand and model number (and, if applicable, the adapter plate.)
    I saw an HM306-5E on Ebay, but the -5E appears to be from a completely different machine and mechanism. Too bad... the price was perfect.
    Thanks everyone - it seems reasonable; hopefully someone out there will have done this.
    Torin...
    Sep 2019
    15
    I know the original post is ten years old but I’m in the process of setting up a chnc iii with a bison chuck . I can’t find any info . Can I cap the air lines to the collet closer and turn off a parameter so I can run without it and it’s major air loss so my compressor isn’t constantly running?
    Quote Originally Posted by torinwalker View Post
    Torin...
    Mar 2010
    1852
    Re: Anyone using a MANUAL chuck on their CHNC lathe?
    I picked up a used Buck power chuck and made an adapter to fit into the 16C collet holder.
    Attachment 462372Attachment 462374Click image for larger version.
  1. Replies: 13
    Last Post: 09-28-2015, 05:04 PM
  2. Manual chuck for EMCO compact 6P CNC lathe
    By rot in forum EMCO Lathe
    Last Post: 07-31-2011, 12:33 PM
  3. WTB CHNC II+ OP MANUAL
    By Pbullets in forum Hardinge Lathes
    Last Post: 11-04-2010, 04:39 PM
  4. Any Ideas on Manual Indexing a Hardinge CHNC Turret?
    By JP Hardinge in forum Hardinge Lathes
    Last Post: 01-04-2010, 06:03 PM
  5. manual chuck on mori lathe
    By SHKROHN in forum Mori Seiki lathes
    Last Post: 09-22-2008, 04:50 PM
