586,103 active members*
3,028 visitors online*
Results 1 to 7 of 7
    Nov 2005
    11
    Cool Heidenhain TNC355
    Hi about 4 years ago I bought a number of machines at auction and have now gotten all of them operational and working. Except one, it is a supermax cnc 40 miller. someone has removed the original control and installed a TNC355 control with heidenhain linear scales on all axes.There were a few blown fuses and a 12 volt power supply that needed fixing,with all that said the control comes up an seems to work fine I can jumper the drives an get all of them to operate. Problem is the entire parameter list all of them are gone.As I understand it after the batteries expire in the control all the parameters are lost and since I didn't commission this control I don't have them saved to disk.I have all the manuals for this but their beyond me I have had experience on other controls with changing a parameter or too change the operation of something however this is much more involved.How much af a deliema am I in, or should I dig a hole and drop it in?
    Any and all help or suggestions welcome.
    Thanks Tom
    Apr 2003
    40
    Heips Machineguy,
    I have a parameter list for TNC355 somewhere on one of my computers. I can dig it up for you on monday if you wish.You coul put them in via R232- port. although its from a Mikron WF 21 toolroom milling machine, so I dont know how it´ll work in all details.
    Regs OsmoP
    Caution for growing spindels
    Nov 2005
    11
    Thanks that would be great, sound like it may be close to the same thing. This machine has only xyz axes. As far as the spindle goes its just a var. speed head like on most toolroom mills. although the control may control the start relay for the spindle.
    Apr 2003
    40
    HI,
    Send me an e-mail,ill reply to it with mp:s
    Nov 2005
    11
    Thanks Oopee, my address is [email protected]
    Feb 2017
    Re: Heidenhain TNC355
    I have a TNC 355 i want to know if you can help me with the parameter #0 to #300 I need your help to install I have a Bridgeport interact 412 Thanks M. Haq
    Feb 2012
    42
    Quote Originally Posted by windsor123 View Post
    I'm uploading pics of my 412 V parameters. It has the TNC 355 controller
    Spindle is 6000 rpm, 7.5 hp
    Let me know if you need better pictures, or if these help you?
  1. Heidenhain TNC355 postprocessor
    By vasyl markiv in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 10-19-2022, 11:46 AM
  2. Replies: 0
    Last Post: 10-12-2013, 08:37 PM
  3. Need Helical Interpolation example for Heidenhain TNC355
    By soweebee in forum Bridgeport / Hardinge Mills
    Last Post: 01-22-2013, 05:16 PM
  4. Heidenhain tnc355 monitor black.
    By Oviksnc in forum DNC Problems and Solutions
    Last Post: 02-21-2011, 05:27 PM
