586,035 active members*
3,666 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Need Help.............mastercam X5 and Mach3
    Jan 2007
    7
    Exclamation Need Help.............mastercam X5 and Mach3
    I'm having trouble with the Mach3 in Mastercam.
    From what I could see the problem is in the lines where I and J are generated
    Example: Y11708 N1460 X-5624, I-12 154 J34.198
    Anyone know if this has a solution?
    I continued my work depends on the solution of this problem ...........(group)
    Dec 2008
    717
    I am not familiar with mach 3 so I won't be much help other than to say to get with your mcam reseller and have them trouble shoot this for you...which I assume you have tried?
    Outside that, try emastercam. Perhaps someone there uses both.
    Tim
    Jan 2007
    7
    Quote Originally Posted by WallyL7 View Post
    Thanks for your time my friend .................. finally resolved the problem myself
    Dec 2008
    717
    Quote Originally Posted by Scooby-NH View Post
    One of the things about starting a string is to have it come to some sort of conclusion. If you solved it great...but perhaps you can state what you did in order to fix your problems so we don't have this string again.
    You never know who it can help in the future.
    Tim
    Jan 2007
    7
    Exclamation
    You have good reason ............... the whole problem is the values ​​of I and J values ​​of these lines that exceed 600 mm.
    And this problem still happens sometimes depending on the machining.
    Using the "Surface High Speed ​​toolpaths" in a cavity the values ​​fall outside the area of the machine I'm using that is 350 by 250 in X-Y
    Already when I use it on a boss values ​​are within the limits of the machine I'm using.
    So do not completely solved the problem ............ Mastercam some expert out there could provide a solution to this problem.
  1. I need a little help setting up Mastercam X4 with Mach3
    By 8ABagel in forum Post Processors for MC
    Last Post: 02-20-2012, 12:12 AM
  2. I need help with mastercam x3 to mach3
    By roger2525 in forum Mastercam
    Last Post: 02-22-2011, 11:10 PM
  3. MasterCam x4 to Mach3
    By Robert M in forum Post Processors for MC
    Last Post: 12-23-2010, 09:40 PM
  4. mastercam x4 to mach3
    By b1078 in forum Mastercam
    Last Post: 08-11-2010, 05:32 AM
  5. Mastercam and Mach3
    By flipper in forum Mastercam
    Last Post: 12-31-2006, 07:13 PM
