586,060 active members*
4,200 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki lathes > replace convertor for mori seiki sl35 fanuc 10t
Results 1 to 6 of 6
    Jan 2009
    117
    Arrow replace convertor for mori seiki sl35 fanuc 10t
    i have a mori seiki sl35 machine. can i replace spindle motor line to converter? if yes, please explain me how to replace?
    Feb 2009
    6028
    Spindle motor line to converter? please explain what you want, this makes no sense.
    Jan 2009
    117
    Quote Originally Posted by underthetire View Post
    my spindle drive no working due to some power break down, there are somany chips and transisters flash. therefore I like i remove this unit and replace to that place invertor? but this machine control is very old, that's why i like to know, can i replace this unit via invertor?
    Feb 2009
    6028
    Ok, so you want to replace the spindle drive. Is this a Fuji drive or Fanuc drive. If fanuc, what model. If digital one, you would need to re configure the control to analog and find correct drive, and replace motor feedback. It would be much cheaper in the long run to just get the Fanuc one fixed.
    Jan 2009
    117
    This is fanuc control 10T mori seiki lathe machine.
    Fuji electric EP-2838D-C, Power Circuit EP-2259B, Anolog Drive
    spindle motor: 22kw, 160V, frq(30-150Hz)
    please advice me some suitable invertors for my machine. if i bring new model invertors such as Siemens, Mitsubisi, etc.. can i replace to my machine?
    thanks.
    Jul 2011
    21
    Re: replace convertor for mori seiki sl35 fanuc 10t
    Hi asfar. Do you have a back up of you machine? i have one identical.
  1. Mori Seiki AL-2 Fanuc 10T
    By davesnd in forum Mori Seiki lathes
    Last Post: 11-26-2018, 07:39 PM
  2. Mori Seiki SL35
    By Ian King in forum Mori Seiki lathes
    Last Post: 01-23-2014, 07:41 AM
  3. mori seiki sl-3a with fanuc 6t
    By cmo in forum Fanuc
    Last Post: 04-05-2012, 12:24 AM
  4. Mori Seiki Lathe SL35 Q-setter
    By ceilingwalker in forum Mori Seiki lathes
    Last Post: 07-02-2010, 12:22 AM
  5. Mori Seiki SL-20 Fanuc 10T
    By premier_industr in forum Fanuc
    Last Post: 12-15-2009, 02:55 PM
