i have a mori seiki sl35 machine. can i replace spindle motor line to converter? if yes, please explain me how to replace?
Spindle motor line to converter? please explain what you want, this makes no sense.
my spindle drive no working due to some power break down, there are somany chips and transisters flash. therefore I like i remove this unit and replace to that place invertor? but this machine control is very old, that's why i like to know, can i replace this unit via invertor?
Ok, so you want to replace the spindle drive. Is this a Fuji drive or Fanuc drive. If fanuc, what model. If digital one, you would need to re configure the control to analog and find correct drive, and replace motor feedback. It would be much cheaper in the long run to just get the Fanuc one fixed.
This is fanuc control 10T mori seiki lathe machine.
Fuji electric EP-2838D-C, Power Circuit EP-2259B, Anolog Drive
spindle motor: 22kw, 160V, frq(30-150Hz)
please advice me some suitable invertors for my machine. if i bring new model invertors such as Siemens, Mitsubisi, etc.. can i replace to my machine?
thanks.
Hi asfar. Do you have a back up of you machine? i have one identical.
