586,077 active members*
3,712 visitors online*
Page 55 of 88 545535455565765
Results 1,081 to 1,100 of 1750
  1. #1081
    Jan 2007
    131
    Just a thought... With the hollow box designs has anyone look at trying to reduce the noise? I've watched a couple of movies in here (and like mine as well) most of the noise seems to couple from the steppers into these really
    nice wood sounding boards...
    Perhaps stuff the box with Styrofoam packing peanuts or something?
  2. #1082
    Once the dust extractor and router are going the steppers are silent
  3. #1083
    Aug 2004
    3215
    Quote Originally Posted by David Da Costa View Post
    That is true, once everything is on that is the noise you try to surpress with its own room or something, not the stepper noise.
  4. #1084
    Jan 2007
    10
    Hey Joe,
    I have been lurking here for a couple of weeks. I am impressed with your cnc build. Pretty incredible. I own a sign shop and have a Dimension 200 router, which I have had for over ten years.
    My question is this. On my router I use a layer of 6mm expanded pvc as a sacrifical table. This is installed in strips with double sided tape.
    the entire layer is milled with the router to an even layer. Then a 1"x 1" grid system is engraved into the table with an engraving bit, along with the numbers of the x and y coordinates along the two edges. Ever consider this approach on yours?
    This makes my table match very my router travel perfectly. And when the table gets marred it can be milled down a little more to make a new clean surface. When worn out I peel the entire layer, and put on a new one with double sided tape.
    Any thoughts? I am helping my cousin as he begins to build on of yours.
  5. #1085
    Aug 2004
    3215
    sure that would work fine with a grid, most people use MDF because it is alot cheaper than the PVC. How much do you pay for yours?
  6. #1086
    Jan 2007
    10
    Sintra in 6mm (1/4") is around $50 a sheet in white, a little more in colors.
    In 10 years I have changed my strips about 7 or 8 times. I run my router on average about 3 days a week, 4 or 5 hours of actual running on those days.
    On my router (cutting area 31.5" x 35.5") I can get enough strips from a sheet to cover my table 5 or 6 times.
    thanks
  7. #1087
    Aug 2004
    3215
    Post some pictures of it
  8. #1088
    Jan 2007
    20
    I have a Question for you Joe. In a previous post in this thread you mentioned that using 1/2" ply may introduce chattering. http://www.cnczone.com/forums/showpo...&postcount=127
    I have the plywood on hand from a previous project that never went anywhere and had planned on using it to make the CNC. Since the machine is bolted down, I'm guessing only the moving parts would be the concern for weight/chatter. Would gluing up 1/2" and 3/4" ply for the gantry uprights(or 2 pieces of 3/4") instead of 2 pieces of 1/2" prevent chatter? Or by doing that would I then introduce too much weight into the gantry?
  9. #1089
    Aug 2004
    3215
    Quote Originally Posted by ezgoin View Post
    The plywood will be fine to use, as long as you use some bracing, either by a side angle brace such as "Jay" did on his, or threaded rods through the gantry sides as i have done on mine. The Key tp the best cutting is to make the machine as stout as possible, yet making it light as possible also.
    Joe
  10. #1090
    Jan 2007
    20
    I saw the angle jay had attached and loved the idea, will definitely do that. By threaded rods through the gantry, do you mean other than the Y torsion box and Gantry bottom?
  11. #1091
    Aug 2004
    3215
    you can see them in this picture.
    http://www.cnczone.com/forums/attach...4&d=1169267356
  12. #1092
    Jan 2007
    20
    Got it, Thanks for your help. I need to dig the camera out and start a log I suppose
  13. #1093
    May 2003
    35
    Our local Menards sells this recycled plastic sheet stuff that is about 1/4" thick that could be used for a sacrifical top, I think that it is less than $50 a sheet and it would mill up pretty good also. I think that if you looked at most home improvement box stores you should be able to find it, I think it might also come thicker.
  14. #1094
    Jan 2007
    10
    Hey Joe,
    Attached are some pictures of a very well worn table on my Dimension 200.
    This has been on without being re-milled for 9 or 10 months of hard use.
    When this was taken I had my engraver motor on the table.
    I should mention one of the nicest things about the pvc is how well it holds tape, and how well it cleans back up after much use.
  15. #1095
    Jul 2005
    253
    Where do you get your pvc from?
    Take it easy.
    Jay (www.cncjay.com)
  16. #1096
    May 2006
    954
    anyone have the dust collection dwg? trying to find it but can't locate it, would like to cut it today as I have the dust collection piped in with a direct line to my dust collector.. would like to connect it up, this machine gets pretty damn dirty without it, the bearings fill up pretty good too
  17. #1097
    Brian, were the v-carve files no good that I sent you via email?
  18. #1098
    Jan 2007
    10
    Quote Originally Posted by dighsx View Post
    Hey Jay,
    Trade name Sintra comes from any sign supply company. In Michigan Wensco is a good bet. They have several locations, including Grand Rapids and In Detroit area.
    Have any trouble finding it I can give you a list if you tell me where you are.
  19. #1099
    Letterguy, is this the stuff you use? http://store.foamboardsource.com/sin...a-pvc-6mm.html
  20. #1100
    May 2006
    954
    which files? you sent me two in the past, z test and david.. just want to cut the bracket out and mount it, I have all the other dust collection hooked up
  1. Two more of Joe's CNC Model 2006
    By JLT in forum Joes CNC Model 2006
    Last Post: 01-31-2019, 02:27 AM
  2. [AU] Joe's 2006 Model
    By nat.andrews in forum Joes CNC Model 2006
    Last Post: 11-11-2013, 11:50 AM
  3. Electronics for a Model 2006
    By joegtp in forum Joes CNC Model 2006
    Last Post: 08-31-2011, 04:43 PM
  4. New to Joe model 2006
    By Darroll in forum Joes CNC Model 2006
    Last Post: 01-16-2008, 11:31 PM
  5. JOES cnc MODEL 2006 R-1 or R-2???
    By Khalid in forum Joes CNC Model 2006
    Last Post: 11-11-2007, 06:58 PM
